Pulled Vort Blower Running NA Question
Old Feb 18, 2008 | 03:54 PM
Barzten1's Avatar
Barzten1
Default Pulled Vort Blower Running NA Question
Ive done it before but I cant remember a couple things. I pulled the blower and some piping and plugged up the intercooler holes. I fed the oil return line into the rubber oil hose. I cant remember what Im supposed to do with the vacuum line from the plenum to the bypass valve. Also should I increase my fuel pressure or lower it since Ill be running rich as hell. Thanks. Jason
Old Feb 18, 2008 | 04:08 PM
clifftrail's Avatar
clifftrail
If your running the SS box, then there is a vac connection that tee's off and it goes from the ss box, intake, and by pass valve. Is that what your asking?
Old Feb 18, 2008 | 04:11 PM
Barzten1's Avatar
Barzten1
No Im running a UTEC. There is a vacuum line from the bypass valve to the SSV manifold. I think Im supposed to block it off. Thanks for the input.
Old Feb 18, 2008 | 04:18 PM
str8dum1's Avatar
str8dum1
you shouldnt be running rich as hell bc you will never get past the 0% load column, as there's no boost. your tuner shoulda scaled the 0% load column so it ran/idled like stock.
I take off my blower belt and the car runs like it did off the lot.
yes, you have to block off that vacuum line.
you shouldnt have to change your fuel pressure either, as that should been set at a baseline before you tuned. You regulator increases fuel pressure with increasing boost. Since you are not boosted, theres no need to increase the pressure.
Old Feb 18, 2008 | 04:22 PM
clifftrail's Avatar
clifftrail
Sorry, didn't see the initially, if your just removing the S/C for maintenance, then just block off that vac nipple on the intake. Don't really know with your set-up, but on mine that is an unused nipple for vac and it sounds like the only place yours is going is to the BPV. Can't really tell just from reading though, GL.
Old Feb 18, 2008 | 04:30 PM
Barzten1's Avatar
Barzten1
Thanks alot fellas.
May 12, 2016 07:42 PM
Vigman
Nov 17, 2015 04:34 AM
Sunset350ZR
Nov 15, 2015 05:45 AM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
reno56
Cooling System
Sep 19, 2015 11:34 AM
