Took the plunge..... I'm going FI!!!
Old Mar 14, 2008 | 05:44 AM
  #61
ChrisCJ99's Avatar
ChrisCJ99
thanks!!! But I'm debating if I should stay open waste gate or not.... Its so damn loud! I'm afraid to even get on it cuz it just draws so much attention.... Is it difficult to close that?
Old Mar 14, 2008 | 07:46 AM
  #62
Townshed55's Avatar
Townshed55
Sweet man get some pictures up asap. I ran an open w/g on my Eclipse and I hear you on how loud they can be, its crazy! Definitely badass but it might get the wrong kind of attention. Congrats on the setup, I'm very jealous.
Old Mar 14, 2008 | 01:34 PM
  #63
iknowitsfast's Avatar
iknowitsfast
i would REALLY like to see some pics and if possible a vid...and are you on a stock block? How much did they charge you for install? Congrats man!
Old Mar 15, 2008 | 10:20 AM
  #64
ChrisCJ99's Avatar
ChrisCJ99
I'm running a stock block right now. They charged me about $1700 for the install, (after taxes, parts, little details) but it was a VERY nice and clean job Couldn't have asked for a better install job
Old Mar 15, 2008 | 10:22 AM
  #65
ChrisCJ99's Avatar
ChrisCJ99
Here are some pics I'll post a vid when I get a chance to record one
Autometer Boost Gauge and AEM Uego wideband gauge
Open wastegate
They fitted the coolant lines with a nice mesh sleeve. Looks clean
Old Mar 16, 2008 | 01:57 PM
  #66
taurran's Avatar
taurran
Nice looking install, but I noticed they left out the turbo heat shield that comes with the kit. I think this is very important to have. Do you know what they did with it?
Old Mar 16, 2008 | 02:03 PM
  #67
ChrisCJ99's Avatar
ChrisCJ99
The shop said that the fitment of the heatshild sucked, so I guess they decided not to install it...... I'm sure they still have it at the shop (I hope!) What are the risks/cons of not having the heat shield? Obviously it reduces engine bay heat, but what else?
Old Mar 16, 2008 | 02:08 PM
  #68
taurran's Avatar
taurran
That turbo is very close to that pipe. I think you may have to trim the heat shield to get it to fit snugly but it will fit. I'd recommend taking off the intake pipe, getting some clippers to trim it back around the base, then using utility wire to fix it in place.
Old Mar 16, 2008 | 02:13 PM
  #69
ChrisCJ99's Avatar
ChrisCJ99
Ok. I will tell the shop to put it on.... Is it a time-consuming process to put the heatshield in? Also, is it really bad to ride around without this heatshield on?? The soonest I can get to the shop is this Tuesday....
  #70
doug's Avatar
doug
the engine makes power because of the cold air rushed through the charge pipes.. does it make sense to you to have the cold air coming out the Intercooler to the charge pipe to then be heated up again by the hotside of the turbo right next to it? without that heat shield you are robbing yourself of major power.. the design itself to have the hotside turbo next to the charge pipe was dumb in itself.. putting a heat shield was putting a bandaid on the design.. you my friend have now removed the bandaid and are running around in a diseased lake filled with bacteria with an open wound
Old Mar 16, 2008 | 02:17 PM
  #71
ChrisCJ99's Avatar
ChrisCJ99
Good point Doug.... I've heard that they sell aftermarket Turbo Blankets that are REALLY effective in reducing heat... Does anyone know where I can find one and how much they cost?
  #72
taurran's Avatar
taurran
Actually, the pop gets every bit as hot from the point at which it bolts to the front timing cover of the motor. The intake plenum gets hot as well just from normal operation. It's not a deal breaker by any means but a nice feature to have.
Your car made 388whp without it which is very nice on a reflash. I don't think it will majorly harm anything.
It should take the shop no more than 15-30 min to get it in there depending on if they take the intake piping off.
Old Mar 16, 2008 | 02:19 PM
  #73
taurran's Avatar
taurran
I can tell you first hand that's an overstatement. I have a turbo blanket and while I can pop the hood and put my hand on it and it will be luke warm to the touch, the intake piping will still be hot. Even with a blanket on, the motor produces a major amount of heat in itself that will heat up the charge piping in the engine bay.
Let a TT'd car sit and idle after heavy use and it'll get hot as well.
  #74
ChrisCJ99's Avatar
ChrisCJ99
Gotcha... Thanks for the tip And lemme say..... TAURRAN IS THE MAN!!!! This guy knows his stuff!
Old Mar 17, 2008 | 11:18 AM
  #75
iknowitsfast
Thanks for the pics! keep us updated on your car!
Old Mar 28, 2008 | 09:50 AM
  #76
ChrisCJ99's Avatar
ChrisCJ99
so just a lil update... Ive since added a PTP turbo blanket (makes a HUGE difference in engine bay heat!!!) and a Turbo XS rfl BOV. Ive had a couple SES lights for codes 1273 and random misfire. I switched the spark plugs to the one step colder NGK plugs. And I swapped the position of the O2 sensors, and the SES light is gone! HUGE thanks to S&R for the entire install and customer service. They catered to me as if I was their ONLY customer!!! They cleared my codes within minutes of arriving at the shop four days in a row and they did an awesome job of problem resolution. Anyone in Florida needs to go to this shop!!!
Old Mar 28, 2008 | 11:13 AM
  #77
iknowitsfast
Good for you Chris! Now then.....ummmm....wheres the video mannnnn!!! lol
Old Mar 28, 2008 | 11:54 AM
  #78
ChrisCJ99's Avatar
ChrisCJ99
Haha. Trust me, I'm workin on that. Just waiting for my new BOV adapter to come in Monday. But right now the streets are INFESTED with cops!!! So its hard to run anywhere. But I'll get something next week hopefully
Old Mar 28, 2008 | 12:29 PM
  #79
Wholey Smokes's Avatar
Wholey Smokes
Hey congratulations on your new kit. I have a UTEC, wideband, electronic boost controller (from my last car), clutch, flywheel, and LSD sitting in my garage and I've got $5000 burning a hole in my pocket. Posts like this make me want to order a kit right now.
Old Mar 28, 2008 | 04:20 PM
  #80
Ed 718's Avatar
Ed 718
BRAVEHEART
And I swapped the position of the O2 sensors, and the SES light is gone!!!!
haha I think you called in today to Turbonetics correct? I think someone called in today about the same thing but spoke to greg which his cubicle is right next to mine and he asked me what to do.
