Code 1136
Sharif at Forged (they F'N rock!!) check the voltages with a UTEC installed. He saw 5V/12V on both sides.
The voltage tests are done on just the harness with no solenoids attached. Getting the passenger solenoid out is a lil tougher, but probably need to do that as well just to make sure its not a combination of problems.
Pretty much makes me think that the ECU is bad. Now to find a good one to swap out to and confirm. Sheesh!! so many bad luck problems, so little driving.
Not sure if this helps any but I use this at work to check codes
http://www.troublecodes.net/OBD2/Pcodes.shtml#300
Thanks Ed.....
Code P1136 on that code list indicates a fan control circuit malfunction.
Here is on I found being Nissan specific. http://www.nissanhelp.com/Ownership/Common/codes3.htm
JET
JET
Originally Posted by JETPILOT
Thanks Ed.....
JET
JET
Originally Posted by Kwame@z1
^^^ WHAT? What was the point in posting if all your going to say is "I know how to solve your problem but I can't tell you how."
Why don't you PM the guy and help him out?
just go download a service manual.
this is a link for a 2003 350z service manual. You can find the engine trouble codes in the ec.pdf file.
http://www.*********.com/files/manua...50z-manual.zip
for seome reason, the is baord won't allow me to link to the other site, but the "*" need to be replaced with "3 5 0 z - t e c h"
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
