Vortech Installation ?!?!
Old Mar 4, 2008 | 02:22 PM
JonnyC's Avatar
JonnyC
Originally Posted by turtle1678
Alright one last question.. My z is my everyday car and I have my own business, I dont have like 10 hours in a day really to spend doing this, is it possible to do it little by little? Obviously not hooking up the oil lines and fuel pump first but I mean like the intercooler and the bracket and belts like split things up or is that not going to work.
I'm thinking of actually installing almost everything in my garage, then possibly taking it over to my friend's place where he has a lift to do the final stuff (tap upper pan, high-flow cat install, etc.). Who knows, I'll probably just end up doing everything in my garage.
You can probably install the bracket, blower, intercooler, and pipes, but then leave the stock serpentine belt on there until you get everything else hooked up. But you'll probably have to remove the blower again to get the oil lines installed. I would just start on a Friday night and shoot for getting it done in a weekend. If you don't, then I would try to find another car to drive around until you get it done.
Old Mar 18, 2008 | 05:23 PM
turtle1678's Avatar
turtle1678
So Im gonna try to get it all done this weekend but I was wondering if I do hook everything up can I drive around without the cog belt for the blower on until I can take it to a shop to get a dyno done and the a/f and everything else checked??
I can hook everything up even the feed and drains into the blower right?? and drive it without any problems
does it matter if the air filter is hooked up and goes through the IC??
Old Mar 18, 2008 | 05:29 PM
turtle1678's Avatar
turtle1678
one other thing I bought my kit used and I have heard stories about faulty ss boxes the last owner said worked no problem is there a way to know other than when I finish the install whether or not it works??
Old Mar 19, 2008 | 06:26 PM
turtle1678's Avatar
turtle1678
Old Mar 20, 2008 | 06:17 AM
jpc350z's Avatar
jpc350z
Gotta plug and play to find out..
350Z_Al
Oct 29, 2020 07:44 PM
