Help Car won't start
Old Mar 3, 2008 | 08:40 PM
Bashar368's Avatar
Bashar368
Default Help Car won't start
Basically the car sits in the garage, today I tried starting it but it will not crank, the last time I started the car was about a week ago. The battery is about 6 months old, the car is supercharged with a vortech kit thats been on the car for about 1200 miles (yes 1200 miles in 6 months). I took out the battery to replace it tomorrow, but is there anything else I should check just in case it's not the battery.
I tried jumping the car with my ford f150 truck without luck, the lights on the interior are really dim but got a little better as I began to jump it. Is there a fuse I should look for and where might it be. I check the fuse box under the steering wheel and next to the battery in the engine bay.
I did a search.
Old Mar 4, 2008 | 07:37 AM
Bashar368's Avatar
Bashar368
anyone
Old Mar 4, 2008 | 10:12 AM
THE ROADSTER's Avatar
THE ROADSTER
sound like battery, I had a same problem last week.
Old Mar 4, 2008 | 10:14 AM
styles's Avatar
styles
+1 on the battery
Old Mar 4, 2008 | 11:36 AM
InZomniac's Avatar
InZomniac
Most likely the Battery. Just FYI there are 3 fuse panels in the Z. If you look behind and under the battery there is one more.
Old May 8, 2008 | 05:24 PM
jamaicanj's Avatar
jamaicanj
How would the fuse panels come in to play with the car not starting?
Old May 8, 2008 | 07:09 PM
KPierson's Avatar
KPierson
When you replace the battery also look in to doing something like this:
https://my350z.com/forum/audio-and-video/199783-external-battery-charger-mod.html
I only drive my car about 4-5,000 miles a year so it sits a lot. I installed a quick connect plug to a trickle charger that always keeps the battery topped off. If you are going to "store" a car it should either have the battery disconnected or the battery should be connected to a trickle charger.
The unit I installed has failed already and I replaced it with a slighty more expensive unit, but it does the same thing.
Old May 8, 2008 | 07:14 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Battery
Old May 8, 2008 | 07:32 PM
350 Rookie's Avatar
350 Rookie
its the vortech.
I highly recommend a swap with greddy twins. that should solve the problem, no doubt.
Old May 8, 2008 | 07:56 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Originally Posted by 350 Rookie
its the vortech.
HURRY BEFORE YOU DAMAGE YOUR DIGNITY
Old May 8, 2008 | 07:57 PM
haeshik's Avatar
haeshik
^what they said, its battery
aarrgghh
May 1, 2022 11:04 AM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
