Anyone with a DIY on EBC?
Old Mar 4, 2008 | 03:23 PM
jeffie7's Avatar
jeffie7
Default Anyone with a DIY on EBC?
Wondering if anyone knows of any DIYs for installing a boost controller in the 350Z
Looks pretty straight forward, however, its always nice to see it done.
Old Mar 4, 2008 | 04:07 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Jeff i install everything myself but when it comes to electronics i wont touch it.Pm dave at ft as he installed my hks evc6 unit.
Old Mar 4, 2008 | 05:16 PM
jeffie7's Avatar
jeffie7
If I get anyone to install it, FT would be where I'd send it, however it really doesn't look hard at all.
12v power
12v power ign
ground
throttle signal line and engine rpm signal line are the two that I question, I've yet to pull out the Z manual but I'm sure I could find it. I'm just trying to see if anyone has a DIY or pictures of what wires they used.
I'm also not in any hurry since the car isn't even here at least not for another week or so. also the turbo kit hasn't come in yet.
Old Mar 4, 2008 | 05:43 PM
failsafe306's Avatar
failsafe306
What kind of BC? You don't need a tach or TPS signal.
Old Mar 4, 2008 | 05:58 PM
jeffie7's Avatar
jeffie7
HKS VI
If thats not needed then the install would be super straight forward.
I wonder why it needs a constant 12V as with a 12V ign. I guess so it doesn't lose what ever settings are saved? then again maybe I read it wrong and it only needs a 12V ign.
I opened the package at work and read over the instructions once, again it wont get installed for awhile so I didn't dig into the details.
As far as the hoses and such goes, it looks super easy.
Old Mar 4, 2008 | 06:17 PM
failsafe306
You'll need both the 12v constant and 12v ignition. Alot of gauges are that way. Just like a stereo.
Old Mar 4, 2008 | 06:35 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
if you need the throttle position line or rpm signal lines you can goto pins 50/62 or 60/52 (cant remember the numbers). You have to dig through the wiring harness on the ecu to tap them. check the nitrous boards, they have the pins and information there.
Old Mar 4, 2008 | 06:38 PM
jeffie7's Avatar
jeffie7
Thanks!
Old Mar 6, 2008 | 07:17 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Did you ever find anything out for sure?
Old Mar 6, 2008 | 12:19 PM
rrmedicx's Avatar
rrmedicx
For basic general boost controller operation, you don't need the RPM and speed sensor wires connected. Just as you stated, 12V, 12V switched power, and a ground.
If it helps, I used an HKS EVC6 and based on your selection for location, I chose, just above the shifter on the curved portion of the console below the temp dials...
I lifted the center console and tapped the cigarette lighter power for 12V switch power & found a suitable ground. I don't think the EC6 needs constant 12V. It has internal memory so constant 12V is not necessary.
I had it up and running in about 30 minutes. The hoses are very straight forward...only problem was my instructions were in Japanese.
Good Luck.
Old Mar 6, 2008 | 12:34 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Most electronics draw their power from the constant +12, and only use the switched +12 as a signal to switch on/off. The reason behind this is that many switched +12 lines have a low current rating, whereas constant +12V are usually rated for a higher current.
The EVC VI probably doesn't draw a lot of amps, so it should be alright, but I would still attach it to a constant +12V rather than only to a switched +12V
Old Mar 6, 2008 | 01:57 PM
jeffie7's Avatar
jeffie7
I figured the EBC used the speed/rpm lines to help it with building boost in different gears. Or does the EBC learn due to the load of the motor/boost?
If I only need the 2 12V and ground I'll just tie it in with my gauges and hard wired radar detector. Both of those tie into the lines where my A/V box is (tv in the dash) that should be easy enough. The rest of the install looks simple as can be.
Once I sit in the car with the gauge I'll figure out a placement, it is going to double as my boost gauge so I want it somewhere I can see it. Then again as long as the A/F readings are good, I guess it doesn't really matter, as long as it keeps a peek boost record.
On another note, this EBC is TINY! I use to have a AVC-R, that AVC-R is a big VS this HKS.
Old Mar 6, 2008 | 02:14 PM
DMK's Avatar
DMK
The HKS has the ability to control boost based on speed. So you can set a different boost under a certain speed and raise it up after that (If I read the manual correctly).
Old Mar 7, 2008 | 05:20 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
To be clear:
The EVC only needs a switched 12v source. If you hooked up to a constant 12v source, the evc would be on all the time.
I just installed the medic's old EVC 6, it took about 10 minutes.
I didn't install the RPM/speed or throttle wires. So far boost is pretty stable. I would like to log some boost but...its snowing in Texas.
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
_bit
Oct 2, 2015 07:49 AM
NFAC
Sep 26, 2015 10:11 PM
