!!Alberto's Kryptonite (pics and video inside) -- Sequential Shifter!!
Old Mar 11, 2008 | 05:27 PM
  #121
BOOSTIN350Z's Avatar
BOOSTIN350Z
Joe is working on trying to get a video up tomorrow, for everyone to see.
Old Mar 11, 2008 | 05:37 PM
  #122
BOOSTIN350Z
Just got done driving Joe's Z......and.....WOW! The shifter goes thru the gears sooooo smooth, and the time it normally take to shift manually, is just cut in half. For you Boosted Z, the Shifter will help you Hold Boost Pressure in between shifts, to keep you up in the Power Band with out loss of boost pressure. This shifter would be perfect for You guys, who love to Drag, Track or just Street Race on the Weekends.
Old Mar 11, 2008 | 05:52 PM
  #123
mw9's Avatar
mw9
Can you PM with a price, thanks.
Old Mar 11, 2008 | 05:53 PM
  #124
Alberto's Avatar
Alberto
Cranky FI Owner
If this shifter helps you shift twice as fast and stay in boost you werent shifting well to begin with. For those people-this will do the trick. Not hating-plain and simple truth. This setup is worth the fact that you will never miss a gear alone! I would love to test drive one. Our 4-5 shifts are tricky-especially at high revs, I dream of hitting that gear as fast as others, this will do it no problem.
Old Mar 11, 2008 | 05:55 PM
  #125
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Just stop by the house on your way back from picking up your car, I should have mine in by then.
Old Mar 11, 2008 | 06:00 PM
  #126
Alberto's Avatar
Alberto
Cranky FI Owner
Guess we arent running before/after? That sucks, oh well carry on...
  #127
taurran's Avatar
taurran
Just curious what happens if you don't modulate the clutch correctly? Will this thing try to force it into gear with the clutch engaged, or will it spit it back into neutral?
Old Mar 11, 2008 | 06:01 PM
  #128
Alberto's Avatar
Alberto
Cranky FI Owner
Id guess it would grind just as if you had mis-timed any manual tranny.
Old Mar 11, 2008 | 06:10 PM
  #129
eagletanggreen
Got Track!!!!!
Yep your still limited to how fast you can engage the clutch. Just imagine your car with a shift pattern back and forward everything else stays the same.
Can you miss a gear with this...Yes (you got to be and idiot to do so)
Old Mar 11, 2008 | 06:22 PM
  #130
taurran's Avatar
taurran
I understand the concept. I was just a bit curious as to the operation, not that I'm saying I suck that bad at shifting or anything.
I'm just wondering if you did, would it sit there and grind until it forced it into gear or you hit the clutch, or would it eventually stop trying to force and throw it into neutral.
If someone just jumped into the car and tried to drive it without knowing how to operate it they could cause some serious damage if it just forces it into gear despite the clutch...
Old Mar 11, 2008 | 06:24 PM
  #131
Alberto's Avatar
Alberto
Cranky FI Owner
Craig it would be the same as if somebody got in your car and tried to shift with no clutch. Chances are the grind will force them out and back to neutral but if done hard enough it will go in...
Old Mar 11, 2008 | 06:34 PM
  #132
eagletanggreen
Got Track!!!!!
+1
  #133
MADScientist's Avatar
MADScientist
It will actually try to go into gear and then get stuck between the cam position in the shifter mechanism... Since it has no way of going back to neutral it kind of goes in between. Then when you push in the clutch you can complete the shift and engage the gear. Interestingly the gear indicator in the dash will be blank if you do this until you fully engage the next gear. Nice side effect since you know right away that you missed.
I know all of this since I have been trying to perfect my clutch action with this thing and I have messed up the timing a few times. The trick to going fast is just taping the clutch peddle to the point it releases and let go, if you go past that you will already have shifted the transmission with the shifter and your foot will be lagging behind. Your foot is the slowest part of the equation. Your hand action is twice as fast so you need to get your foot to do the same... It may come down to adjusting the engagement point on the clutch pedal to get it just right for maximum speed.
Old Mar 12, 2008 | 09:20 AM
  #134
dklau33's Avatar
dklau33
I'm assuming one still has to heel toe rev match when downshifting with this correct?
Old Mar 12, 2008 | 10:55 AM
  #135
rrmedicx's Avatar
rrmedicx
Great discovery. Nice work Joe & Luie. I would love to hear some more hands on feedback. Please keep us posted. Do either of you plan to close up and cover up the mechanism with the provided shifter boot? Curious what it looks like.
Old Mar 12, 2008 | 10:59 AM
  #136
taurran's Avatar
taurran
Nice. That was a great explanation. Sounds like the operation was well thought out.
Old Mar 12, 2008 | 11:02 AM
  #137
taurran's Avatar
taurran
It looks like this. Real JDM quality.
Old Mar 12, 2008 | 11:06 AM
  #138
mikez97's Avatar
mikez97
looks amazing man waiting too see what all it comes down to beating him
Old Mar 12, 2008 | 11:22 AM
  #139
Alfreds Z's Avatar
Alfreds Z
Very interesting. Nice job on this discovery.
Old Mar 13, 2008 | 08:29 AM
  #140
DriftinZ's Avatar
DriftinZ
Vids Yet??????
