Relocated my gauges to my center cubby onto CF panel *PICS*
Old Mar 17, 2008 | 03:15 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Default Relocated my gauges to my center cubby onto CF panel *PICS*
Bought TayTay's carbon fiber cubby panel a month back. Finally got around to swapping the gauges into it.
for those that are interested in a similar panel go here https://my350z.com/forum/forced-induction/345508-feeler-for-carbon-fiber-triple-gauge-panels-for-the-cubby.html
I had a black autometer triple pillar. It is now FS/FT cheap for a oem a pillar without the mounting holes.
Onto the pics.
With cubby closed. It shuts fine with not snags at all.
distance with cubby open:
close up:
Bottom left gauge: Boost/Vaccum
Top middle: Wideband
Bottom right: Oil Temp
So what do ya think?
I may try to start making these panels. Make some for dual 60mm or triple 52mm. Theres just enough room to add buttons and such under the top middle gauge. I even want to make them recessed a bit to allow more clearance. Maybe even a nitrous panel.......
I removed the box from the back of the cubby. It made it easy to run the wires in there and i didnt have to cut it.
and as jamez would say.......im wearing my driving shoes!
Old Mar 17, 2008 | 03:17 PM
D350Z10's Avatar
D350Z10
Looks Great. Clean, Simple, and hidden.
Old Mar 17, 2008 | 03:19 PM
04LIQUIDSILVER's Avatar
04LIQUIDSILVER
Nice .. me like
Old Mar 17, 2008 | 04:32 PM
TayTaythatsme04's Avatar
TayTaythatsme04
wow, looks very nice. Hope the piece wasn't to hard to get mounted in there.
T
Old Mar 17, 2008 | 04:36 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
the mount fit fine with out modification. I test fit it and knew it was good. Got all the gauges transfered and wired. Had to drill for the buttons/led which was nerve racking. Once that was done, i dropped it into the cubby, predrilled some small holes in my cubby and then used those self tapping screws to mount the panel.
Really had to take into consideration the backside of the lid. Its got a huge bulge where the button is.
Old Mar 17, 2008 | 04:42 PM
coachk's Avatar
coachk
It looks good, but was there any other way to mount it where you wouldn't have to use the 2 screws. Maybe 2 sided tape...
Old Mar 17, 2008 | 04:45 PM
terps's Avatar
terps
birkestock wearing mother f*cker.... nice setup, real clean
Old Mar 17, 2008 | 04:52 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
^i wish they were birkenstocks........too expensive. These are knockoffs ( think rotas). Theyre cheap and you cant tell the difference till your up close. Still comfy and i dont care if i tear them up ( 15 bucks a pair)
i bought the panel used with the holes already drilled...........DS tape might work, maye someone else can try?
Old Mar 17, 2008 | 07:56 PM
JAM3Z's Avatar
JAM3Z
Phenom
Nice (as always) DIY-work Chris. Thats a nice alternative to the A-pillar.
Old Mar 17, 2008 | 08:01 PM
THE_SCHROED's Avatar
THE_SCHROED
I spot BRO FLOPS, HAHAHA. Clean setup man
Old Mar 17, 2008 | 08:06 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
thanks man. see my comment about my "driving shoes"
of all things i messed up on the relocation.........was the direction of the led leads. (one has to be positive and the other negative to forward bias the npn junction, swtich them around and no current flow = no light)
Youd think id get that part right. I clearly remember it going through my head like this " Does it matter which wire i attach to the signal and which to ground............nah". As an EE major and fairly knowledgeable of led's, i feel ashamed.
Old Mar 18, 2008 | 06:05 AM
buzzardmountain's Avatar
buzzardmountain
Looks good Chris......
Old Mar 18, 2008 | 06:13 AM
merlin3's Avatar
merlin3
looks good, I did something temporary with mine using some nice abs plastic. I mounted mine using industrial adhesive velcro. I mounted 4 blocks, one in each corner with velcro then mounted the panel to the blocks with velcro. It was sturdy but still removeable. I just took it out though as i have a 7" touchscreen there now that displays all my gauges from my utec and wideband.
Old Mar 18, 2008 | 06:22 AM
reptile718's Avatar
reptile718
I was worried on Sun. when I saw the Z's interior all taken apart with a million wires exposed but it turned out really good Chris. Those gauges are pretty bright I can see why it was a good idea to relocate.
Old Mar 18, 2008 | 06:58 AM
iknowitsfast's Avatar
iknowitsfast
Man i love that! Is this a custom piece or can we purchase something like this online? Inquiring minds want to know! I'd much rather do this than have a triple pod on my pillar.
Old Mar 18, 2008 | 07:21 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Im hopefully going to start making these pieces. Theyre are definitely custom.
Old Mar 18, 2008 | 07:45 AM
QuadCam's Avatar
QuadCam
that's a new name for Birkenstocks. I used to call them Jerusalem Cruisers or Jesus Joggers.
Old Mar 18, 2008 | 07:47 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
thats awesome man...nice and clean
Old Mar 18, 2008 | 07:48 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Looks great. I sometimes wish I didnt have factory nav, so I could mount guages in this cubby.
Old Mar 18, 2008 | 09:14 AM
saberphx's Avatar
saberphx
Where can you buy this and how much?
I want :P
