Vortech SC, bypass valve not functioning?
Old Mar 17, 2008 | 07:47 PM
chaparro78's Avatar
chaparro78
Default Vortech SC, bypass valve not functioning?
I don't know if i have a pressure leak somewhere or if the bypass valve isn't unctioning anymore. Yesterday the jet sound most vortech installs have went away.
Insted of the loud release of air pressure it sounds more like a tire leaking air as it's driven down the road. Has anyone had issues with this?
Old Mar 17, 2008 | 08:30 PM
I am JDM's Avatar
I am JDM
did u check the vacuum connection to the bypass valve?? might have blew off
Old Mar 17, 2008 | 08:33 PM
chaparro78's Avatar
chaparro78
I did, checked the vacuum hose from the fuel presure regulator going into the bypass valve and on up to the intake. even removed the bypass valve to ee if i could manually open and close the valve.
Old Mar 17, 2008 | 08:41 PM
str8dum1's Avatar
str8dum1
if you pushed on the valve with your finger, you f'd it up.
send it in to vortech.
Old Mar 18, 2008 | 03:28 AM
chaparro78's Avatar
chaparro78
are you serious? why would it mess up?
Old Mar 18, 2008 | 04:38 AM
booger's Avatar
booger
Your not going to screw it up by pushing on the valve and opening it ! Its just a spring you would be compressing .
Check all your vacuum hoses , and your intercooler pipes and couplers
Old Mar 18, 2008 | 09:23 AM
str8dum1's Avatar
str8dum1
^^ if you say so,
i pushed in my valve to reseat the o-ring and it was trashed. vortech had to send me a new one.
Its not just a spring, theres a manifold.
Old Mar 18, 2008 | 11:50 AM
booger's Avatar
booger
^^ if you say so,
Ive had mine off and taken apart to put in a new spring . I pushed in on the valve opening and closing it many times . Its still working perfectly
Old Mar 18, 2008 | 03:39 PM
str8dum1's Avatar
str8dum1
interesting. could you go out and push it all the way in now and see if it seals right without taking it apart?
Old Mar 18, 2008 | 06:56 PM
chaparro78's Avatar
chaparro78
i took it in to a shop today and was told the bypass valve was not functioning. have to get with vortech for a rebuild or buy a new one from another vendor.
suggestions?
Old Mar 18, 2008 | 07:01 PM
chaparro78's Avatar
chaparro78
suggestions?
Old Mar 19, 2008 | 04:43 AM
booger's Avatar
booger
suggestions?
I have mine I may sell . It does have the lighter spring in it . It opens and closes sooner than the heavier spring . The shop just took it off and replaced it with the huge one on Vortech's site .
Old Mar 19, 2008 | 07:11 AM
str8dum1's Avatar
str8dum1
Ya, make sure you dont push the new one.
i'd send it back to vortech for a repair. It will be way cheaper than buying a new one.
suggestions?
Old Mar 19, 2008 | 11:50 AM
booger's Avatar
booger
[quote=str8dum1]Ya, make sure you dont push the new one.
i'd send it back to vortech for a repair. It will be way cheaper than buying a new one.[/quote
Your BOBPV must have been screwed up or faulty to begin with when you pushed in on it . Your not going to screw it up pushing in on the valve . Think about it , its the exact same thing it does when on your car .
Old Mar 19, 2008 | 12:14 PM
str8dum1's Avatar
str8dum1
if it didnt matter, why would they tape a HUGE warning sticker on the bottom of a new BPV and explicitly says not to manually push in.
ive never opened mine up, so i do not know what the valving looks like. But it worked, pushed in valve to reseat the o-ring, and it didnt seal.
Vortech confirmed by saying valve was messed up.
Again, not saying you are wrong, that's just not my experience
Old Mar 19, 2008 | 12:28 PM
booger's Avatar
booger
Now that you mentioned it [ its been 4 years ] I think I do remember seeing a sticker on the bov when the kit came new . Im just going by that I know I played with the thing....pushing in on the valve many times when I replaced the spring and it still works great .
Old Mar 21, 2008 | 03:33 PM
chaparro78's Avatar
chaparro78
it got fed exed today. the z will be garaged until i get it back. it's good the weather isnt too bad because i'll be on my GSX_R until the z is running. after i get it back i am doing a whole tune-up on the car followed by a UTEC over at SGP in Houston. Nice road trip should do the car some good
Old Mar 21, 2008 | 04:57 PM
Drewer's Avatar
Drewer
Default Don't push
Yeah, my kit's BOV has a HUGE sticker on it that says it will damage the diaphragm if I push on the plunger.
Old Apr 11, 2008 | 08:10 AM
chaparro78's Avatar
chaparro78
Thw rebuilt one has been on a week now. Definately a lot louder than before, don't know if the threads on the adjustment screw are set the same as the old one. Good thing is that they replaced the bell housing with a red one instead of the blue on that was on there, matches the car better
Old Apr 11, 2008 | 09:45 AM
fishclub's Avatar
fishclub
Mind didn't had the jet sound either, my kit is less than 150 miles. I didn't adjust the valve as the instruction metioned, but I used 7/32 hose. Also, isn't true if you have headers, plenum(SSV) mod, the bypass valve will sound differently(no jet sound) ?
