Watered Down TN
Old Mar 19, 2008 | 12:59 PM
taurran's Avatar
taurran
Originally Posted by allmotor Z
My car just recently started smoking after 15k miles on the kit. I just sent my turbo in though so I can give any results as to how it adds performance or not.
allmotor Z did.
Old Mar 19, 2008 | 01:04 PM
saberphx's Avatar
saberphx
Originally Posted by taurran
allmotor Z did.
Ah hah! So thats the culprit
Old Mar 19, 2008 | 01:13 PM
350Z400rwhp's Avatar
350Z400rwhp
I didn't have mine long enough to give you an honest opinion of it. It's more of a longevity thing than anything. The turbo should be fine as is, IMO.
One thing I'd suggest rather than focusing on the water cooling is the oil return. I'm not sure if you're tapping into a spacer or into the upper oil pan, but either way you'd go I'd suggest using a 45 degree fitting to go into the tap. You could even go out and find a 1/2" to -10an fitting and get a stainless steel return line with a -10an fitting on one end. (the one that comes with the kit is a 3/8" to 5/8" slip fitting) The SS return line will have to be 5/8 inner diameter.
The 5/8 inner diameter SS return line to a -10an 45 degree fitting with a 1/2" tap into the upper pan would be perfect for oil circulation, IMO...
Hey Taurran, do you think the elbow would flow better than a perfectly run line? Does the elbow just eliminate the chance of the return line going horizontal? Seems like keeping the return line right next to the hot engine would help too. Thanks for that idea I'm going to do that with my Vortech. As I want to do the spacer return and the oil return flow is an issue with that supercharger too.
Old Mar 19, 2008 | 02:10 PM
Ace Ventura's Avatar
Ace Ventura
Originally Posted by saberphx
Gotcha.
However I could have sworn I saw someone mentioning that even when they changed from the oilpan spacer to the tapped upper, It still had white smoke. Also what about this fellow a couple posts up who has been running his car fine for 15k miles before white smoke shows up? Perhaps just a straight shot oil return isnt enough in the long run? I guess the oil return line is the most important factor, but I imagine the water cooling would help prolong both the turbo and the turbo seal's life. 15k is a pretty short life for a turbo seal, nevermind all the people who blew them after only thousands.
Allmotor z, how is your return line run? to the oilpan spacer?
I have the fittings that were included with the kit plugged into an oil pan spacer.
Old Mar 19, 2008 | 04:26 PM
taurran's Avatar
taurran
Yeah, it helps you route it perfectly too by keeping the line itself from bending too much and kinking up. It has to be angled to the front to go towards the turbo/blower. On the turbonetics kit, the elbow also helps keep it away from some hot piping.
And yes, another good reason for stainless braided line is that the stainless steel sheath heats up and keeps the oil nice and hot as it returns to the oil pan, which helps flow. It also is rigid and keeps it from bending and forming kinks which will kill the turbo seals.
A 45 degree elbow is best, but in my case I'm only doing a 90 degree because my only option is the front of the spacer. The front of the oil pan spacer and the front sway have very little room to work with so it's a must. Also, with it in the front of the spacer it is a straight shot down. The small 90 degree back into the oil pan isn't a big deal from that angle either, because the forward motion of the car will help oil flow back out of the 90 degree elbow.
Glad I can help.
etkms
Jun 19, 2022 06:30 PM
350z82
Oct 1, 2015 06:25 PM
roadmax
Sep 12, 2015 05:55 PM
PureR3d
Sep 10, 2015 06:23 PM
