Ecu reflash for FI......
Old Mar 25, 2008 | 08:22 AM
al_v's Avatar
al_v
Default Ecu reflash for FI......
I´m tired of the bad cranking that my car have when is warm , too much time to get started , my utec doesn´t have any solution to this problem , I have 550cc injectors with a 3.5 bar FPR.
I´m thinking in a reflash for my bigger injectors , but not sure if with a reflash could be possible to decrease the cranking times, to get a nice time to start my car when is warm , and doesn´t have all that black smoke after that....
I know that this is a tuning thread , but not much people reads the tuning sub-forum.
Old Mar 25, 2008 | 08:25 AM
taurran's Avatar
taurran
There was another thread started here on the FI forum for the same subject today:
https://my350z.com/forum/forced-induction/346383-reflashing-ecu-with-utec.html
Old Mar 25, 2008 | 10:26 AM
str8dum1's Avatar
str8dum1
are you sure your fuel pressure isnt too high. bad cranking when warm is a tell tale sign of high fuel pressure
Old Mar 25, 2008 | 12:27 PM
al_v's Avatar
al_v
My fuel press is good , exactly 3.5 bar when you start the engine.
https://my350z.com/forum/showthread.php?t=346383
But , in that thread , doesn´t have an answer to my question about cranking injector times.
Old Mar 26, 2008 | 04:09 AM
jpc350z's Avatar
jpc350z
Souds like the ECU /injectors are not scaled properly..Black smoke too rich...Excessive cranking time is likely due to the lack of 550 cc scaling...UTEC not involved in starting..
Old Mar 26, 2008 | 06:12 AM
al_v's Avatar
al_v
Yeap , the Utec isn´t involved in the injector cranking times , I need to decrease that times to solve my problem , because stock injectors are 290cc , now I have 550cc , so the cranking times would be around the half of the time ,to get a nice start up in warm.
This is the only issue with the Utec , the car runs perfect , and the black smoke is only after a warm start.Some guy will tell me...... if I reduce my fuel press , would get a better start up , but my injectors are around 90% of duty cycle at wot , if I reduce the fuel press to 3 bar , my injectors would be max out.
But , nobody knows if with a reflash for bigger injectors , the cranking injectors time is decreased
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
