too many choices
Old Mar 28, 2008 | 04:41 PM
2boosted4u's Avatar
2boosted4u
Default too many choices
soo i have been lookn to build my own rear mount turbo kit and im not sure if i should run a gt35r or the gt30r..what do you guys think i should run?? im lookn for about 6-8.5 psi and im goin to run a aem tuner. thanks for your replys in advanced..
GT35r
Compressor Specs:
-T04S 82mm compressor wheel
-0.70AR T04S compressor housing
- Flow Rate 65lb/min
Turbine Specifications:
-84 Trim
-68mm
-0.63, 0.82, or 1.06 A/R. turbine housing available
CHRA Specifications:
-Full steel ballbearing cartridge.
-Oil & Water cooled&lubricated center section
and the
GT30r
Turbine
-Wheel: 60mm w/ 84 trim
-Housing: .63 ar, .82 ar, 1.06 ar
-Maps
Compressor
-Wheel: 76.2mm w/ 56 trim
-Housing: .60 ar
-Maps
Old Mar 28, 2008 | 05:13 PM
wannabuy350z's Avatar
wannabuy350z
both are kinda similar, but i would differently run the gt30r, less spool time, especially you running a rear mounted turbo. bigger ar size the more lagg
Old Mar 28, 2008 | 05:21 PM
athenG's Avatar
athenG
Those look like front mount housing. Just an idea, STS uses TO4E60 O Trim .58 AR housing and boost hit late 3000rpm or close to 4000rpm at 8psi. Any bigger than that then I see more lag. Not really a Turbo expert but just my .02
Old Mar 29, 2008 | 08:02 PM
2boosted4u's Avatar
2boosted4u
right on for the replies! ttt
Old Mar 29, 2008 | 09:22 PM
JonnyC's Avatar
JonnyC
So you're going to fab up everything including the charge pipes heading back up to the intercooler? Or are you going to switch out the turbo on the STS kit? Seems like a lot of extra work/money to do it all yourself, unless you have the means to do it.
Old Mar 30, 2008 | 08:34 PM
2boosted4u's Avatar
2boosted4u
well im not worried about all the welding and im ordering a bunch or mandrel bent pipes to fab everything up and in my mind it seems easiler to have it back there then try n cram it in the motor bay...also cooler temps with it back there
Old Mar 30, 2008 | 09:13 PM
rr_z33's Avatar
rr_z33
good luck with your build. with the turbos being so far away exhaust gases loose heat and velocity so with that said running a 35r will just make the lag worse. so you want to go for a smaller turbo with a rear mount set up.
Old Mar 31, 2008 | 09:35 AM
bigcloud's Avatar
bigcloud
Okay I can finally contribute...:-) On www.maxima.org there are two rear mount turbo maxima's. One goes by the name of streetzlegend. His turbo is similar to the GT35r I believe it's .69 AR and a .63 turbine. I will get more specifics on it, but he runs 10 psi on his stock block VQ30. At first he was spooling later just as everyone has said he would, but now he is able to spool up at the same rate or faster than a front mount setup. All he did was wrap the exhaust housing and piping on the hot side of the turbo to achieve it. So with that being said you can have a rear mount setup that spools just as the same as a front mount. Here is a link to what I am talking about. Thanks....
http://forums.maxima.org/showthread....=streetzlegend
Old Apr 1, 2008 | 08:41 PM
2boosted4u's Avatar
2boosted4u
^ niceeee good info on that ill be sure to wrap it i was thinking about powder coatin all my ic pipes and the exhaust have ceramic coated...still not sure tho but ill be sure to have the exhaust wraped...thanks again everyone more input is always apreciated!
Old Apr 2, 2008 | 05:26 AM
Jonny Boy's Avatar
Jonny Boy
I would go with the gt30 because of spool time.
Old Sep 29, 2008 | 09:11 PM
Mkriebs's Avatar
Mkriebs
Question... what is the difference in the housing on a rear mount or a regular turbo??
**sorry for raising this thread from the dead, but i haven't seen the differences talked about anywhere else, so i figured I would throw it out here and see if anyone knew off hand.
Old Sep 30, 2008 | 05:41 AM
UMW350Z's Avatar
UMW350Z
What is the appeal of a rear-mount turbo???? I just don't get it...cooler temps? be different??? I guess it would be easier to service the turbo itself, but the extra pipes and the distance the compressable air has to go...just seems counter intuitive
May 30, 2017 03:28 PM
kyin
Oct 15, 2015 05:54 AM
jlc280z
Sep 24, 2015 08:43 AM
Shane86
Sep 17, 2015 05:33 PM
