Innovate Wideband Question
Old May 4, 2008 | 09:38 AM
98intrigue's Avatar
98intrigue
I think I found out why my Innovate doesn't work.. I've been getting an E2 code since August. I was looking at the wideband sensor up on the lift the other day and there were 2 spots where the wires were F'd from rubbing on the driveshaft.
Does anyone think I can rewire the messed up spots or is my Innovate worthless?
Old May 4, 2008 | 10:19 AM
diwun67's Avatar
diwun67
My Innovate has given me NO problems since I installed it last year in April...JT tuned the car on his dyno with his wideband for low 11's AF and that's what I'm still getting to this day.
Old May 4, 2008 | 04:14 PM
MR RIZK's Avatar
MR RIZK
As long as the sensor or unit is not damaged then there is not reason you cannot just fix the wires. Keep in mind if the wirs that you are fixing is the ones on the sensor end then these are normally a stainless type wire which is difficult to solder unlike a normal copper wire etc.
Michael
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
