Vortech Installation
Old Feb 20, 2009 | 05:27 PM
  #41
tylerxfire's Avatar
tylerxfire
ok thanks for the heads up....the way u have it u haven't had any problems i take it...how many miles now on ur kit any problems so far?
Old Feb 20, 2009 | 05:42 PM
  #42
Car vs. Driver's Avatar
Car vs. Driver
Hmmm .. probably 2000 miles or so since November. No mechanical issues other than the far left idler pulley on the bracket went bad and I had to replace it (bearing froze).
Almost forgot, take a look at the wiring harness running behind the blower in my pic. That's a bad spot to have that, you'll need to relocate it to the other side of the bracket it sits next to (the air box bracket). If you don't the cog pulley will rip it to shreds - fortunately I noticed it before I started the car
Old Feb 20, 2009 | 05:49 PM
  #43
tylerxfire's Avatar
tylerxfire
yeah u mean the wiring harness u can see right from the inside of the wheel well right?...i moved it and ziptied it back against the car more to make sure it would be out of the way from the pulley and belt.
Old Feb 20, 2009 | 06:15 PM
  #44
Car vs. Driver
Yeah, the black harness that comes up over the wheel well and behind the blower in my pic. You should move it to the other side of the bracket it is sitting next to on the front of the wheel well.
Old Feb 20, 2009 | 06:51 PM
  #45
tylerxfire's Avatar
tylerxfire
ok, where i have it is good, but better to be safe than sorry ill do that tomorrow too...its amazing how close some things are with this..
Old Feb 20, 2009 | 07:43 PM
  #46
Car vs. Driver
I'm bored ... so here you go ...
Old Feb 20, 2009 | 08:05 PM
  #47
tylerxfire's Avatar
tylerxfire
lmao....nice..
Old Feb 20, 2009 | 09:06 PM
  #48
Chef-J's Avatar
Chef-J
Booooosstt!!
Dammm awsome info info info here! I defi look at it when i'm installin mine.
Old Feb 21, 2009 | 01:50 PM
  #49
tylerxfire's Avatar
tylerxfire
well i got it all together and let it sit and idle for a while no leaks anywhere, but service engine light is on, so i have to figure that out tomorrow, have some stuff to do so had to quit for the day, but sits and idles and sounds great...any ideas on the engine light? what maf housing is supposed to be in my 03 z 22680 ca000 i beleive it is right...cause i had to get one and thats what it is and the sensor looked good when i put it in and like i said it runs fine...well guess its hard to tell till i diagnose it... till tomorrow
Old Feb 21, 2009 | 02:52 PM
  #50
str8dum1's Avatar
str8dum1
takes 5 secs to get the error code by using the pedal sequence. each # of flashes is the code. 10 flashes = 0, 1 flash = 1
Old Feb 22, 2009 | 02:03 PM
  #51
tylerxfire's Avatar
tylerxfire
all set was p102 code or somethin for the maf sensor, and maf housing was leaking a little cause the gasket was off a little, so i got it all set and i cleaned sensor while it was out put it back in and cleared the code and its all set now...ill put up some pics later..thanks for everything guys
Old Feb 24, 2009 | 04:04 PM
  #52
tylerxfire's Avatar
tylerxfire
Default pics
few pics i had on my phone before putting bumper and hood back on....its all together now runs great, no engine lights, can't wait to go get it tuned and get some miles on it...
Attached Thumbnails Vortech Installation-side-view-kit-finished.jpg   Vortech Installation-kit-finished-pic-of-blower.jpg   Vortech Installation-kit-all-mounted-front-view-with-cover-on.jpg   Vortech Installation-blower-mounted.jpg
Old Feb 24, 2009 | 04:27 PM
  #53
JonnyC's Avatar
JonnyC
Looks real good. Glad everything went together ok. I'm jealous of the polished plenum
Old Feb 24, 2009 | 04:28 PM
  #54
Car vs. Driver
Good job man ... now get under the car and "not-n-bolt" the whole thing before you strap it down for a tune. Never know what you might find that's loose
Old Feb 24, 2009 | 04:56 PM
  #55
TheFarmer's Avatar
TheFarmer
This thread is the win. Subscribed.
Old Feb 24, 2009 | 06:28 PM
  #56
tylerxfire's Avatar
tylerxfire
thanks man...i have at least a month before it leaves the garage due to winter here....so i will actually be taking the pipes out that are visible in the engine bay and polishing them and cleaning up the engine bay
Old Feb 24, 2009 | 06:30 PM
  #57
tylerxfire's Avatar
tylerxfire
thanks for all the advice...yeah like i said the car won't be leaving the garage anytime soon, so i have been checking things over daily and letting it run and retightening the belt and what not...sucks its winter and i am not gonna drive it for at least a month...then ill be headed to function tuned....
350Z_Al
Oct 29, 2020 07:44 PM
