Need help, service engine/slip/tsc lights are all on.
Old Mar 30, 2008 | 08:53 PM
xtrmspd's Avatar
xtrmspd
Default Need help, service engine/slip/tsc lights are all on.
I have a question about the service engine/slip/tsc lights all staying on. This happened when I installed the competition stage for stillen sc. I sent my piggy back to have it reprogrammed for the upgrade and had the problem and I sent it back to them to erase and reprogram again. But I still have the same problem and my motor doesn't start right away (seems to have too much fuel pumping in).
Anyone else know of this problem and/or anyone know what it might be? Some help would be appreciated. Thanks.
Old Mar 30, 2008 | 10:40 PM
azkt84's Avatar
azkt84
id like to know also. I have a stillen supercharger. and every so often all the lights will come on and it just wont start. just cranks and crank and cranks then after sittin for like an hour or two it finally starts....
in fact my car is at stillen at the moment... been there for like a week and i dont even think they have touched it.
Old Mar 31, 2008 | 02:57 PM
fklentz's Avatar
fklentz
Got a code scanner? Anybody that can afford to go FI should be able to afford some type of scanner for help in CEL issues. Sounds like your car is in limp mode, having a code will tell us what the ECU is having problems with. There are numerous things that can cause this.
Old Mar 31, 2008 | 09:48 PM
xtrmspd's Avatar
xtrmspd
I may have to get a code scanner. But looking at the instructions, there's a "Trouble Shooting" page. For long crank time but car starts, the possible cause could be the "Control Unit Wiring". I will be looking over all the wiring tomorrow to see if there is anything misconnected or maybe installed incorrectly.
azkt, who installed your sc? Stillen? If Stillen installed the sc, I'm surprised that you're having issues. Sounds like they have faulty piggyback programming. It's odd that we both have the same issues, except that mine actually starts within a few seconds. But lights are still on.
Old Apr 1, 2008 | 10:16 AM
xtrmspd's Avatar
xtrmspd
Well... I found the proplem. Apparently it was a wiring problem. One of the wires came out of the plug going to the piggy back.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
