Stillen SC installation improvements
Old Mar 31, 2008 | 08:08 AM
sleeper_g's Avatar
sleeper_g
Default Stillen SC installation improvements
I bought a used Stage 4 so maybe some of these have been updated by Stillen but I don't see them in the latest installation manual.
First, the obvious. Step 14, rerouting the crankcase vent pipe. I didn't like jamming a rubber hose against the injectors so I started exploring why they went that route. a rubber hose is too thick to fit under the pulley so why not use a metal pipe. the pictures tell the rest of the story.
2nd, the bolt on the lower tensioner is 3/8" but the bearing hole size is 12mm. option 1, make the adjusting slot 12mm to match the bearing. option 2, make a special 12mm bolt with 3/8" threads and install the threaded put through the slot (the nut on the back of the side)
3rd, why do they give you unplated bolts? for $5,500 I should be getting gold plated bolts. anyway, you can get the same hardness bolts with zinc plating from fastenal. pictured
http://www.fastenal.com/web/home.ex
well, maybe more later!!
Attached Thumbnails Stillen SC installation improvements-img_3423.jpg   Stillen SC installation improvements-img_3424.jpg   Stillen SC installation improvements-img_3427.jpg   Stillen SC installation improvements-img_3433.jpg   Stillen SC installation improvements-img_3429.jpg
Old Mar 31, 2008 | 02:51 PM
fklentz's Avatar
fklentz
I think there is an updated pulley setup that is 6 rib vice earlier that were 4 rib belts.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
