Turbonetics-engine light
Old Mar 31, 2008 | 04:41 PM
Rmrichards1385's Avatar
Rmrichards1385
Angry Turbonetics-engine light
i just spoke with Turbonetics, and they said it is normal for the slight misfire and the check engine light to b on and that's how all their cars are!?!? Plus the slight sputter sound when its sitting in nuetral is normal? Anyone else experience this? The car runs great, just dont like the "service engine soon" light glarrin in my face.
Old Mar 31, 2008 | 04:51 PM
Rmrichards1385
as talked about in a previous post, taurren asked if multiple or single, and it's been a lil bit since I've seen the code, but I thought it just said "single or multiple misfire."
Old Mar 31, 2008 | 05:10 PM
SouthernG35's Avatar
SouthernG35
My car has the same issues. I have just got used to the check engine light. The slight sputter that I have at idle does bother me some what. I have spoke to the local dealership here about raising my idle about 200 rpm. They said they could do it for like 25 bucks. If that work I will let you know.
Old Mar 31, 2008 | 05:20 PM
Rmrichards1385
nice southern, thanks for the info, thats extremely helpful, although it kinda sux having it, its well worth the benefit! good to know that others really do have the same issue and it wasnt turbonetics just not wanting to deal w another problem. That makes me feel a lot betr.
Old Mar 31, 2008 | 05:22 PM
diwun67's Avatar
diwun67
CEL is normal, but definitely raise your idle to 940rpms, kills the rough idle condition.
Old Mar 31, 2008 | 05:48 PM
taurran's Avatar
taurran
Random Multiple cylinder misfire CEL seems normal on all FI setups on this motor.
The sputtering sound may be a boost or exhaust leak.
The turbonetics reflash raises idle to 1000rpms so if you're not running the reflash it may need to be bumped.
It doesn't sound like a problem to me, just a few issues you need to work out with your setup.
Old Mar 31, 2008 | 06:23 PM
hr2burn's Avatar
hr2burn
Is that "sputter" kinda random? Like 10 seconds on and 30 seconds off?
Although I thought the reflash was awesome, a utec and reflash fixed that problem for me. For the H.P gains you gotta admit these thing were worth it and there are ways to fix them!
Sean
Old Apr 1, 2008 | 03:02 AM
ChrisCJ99's Avatar
ChrisCJ99
I just posted a thread on this issue last week. I was getting a SES light about a week after installing my TN kit. The codes I were getting were "1273" and "P300" I think. (Random misfire and Lean bank one I think). I tried swip swapping the location of the O2 sensors, and it worked for about 140 miles, but then the SES light came back... My car also sputters occasionally. As long as it doesn't stall out on me, then I'm fine with it...
Old Apr 1, 2008 | 08:56 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Keep in mind some Z's are more subject to the random multiple misfire codes. My 03 ( production date 9/02 ) get's it more than my coworker who has the same car and kit. I have a code reader that I used to erase the code but it keeps coming back however it does not effect the performance or anything related to the TN kit.
Old Apr 1, 2008 | 10:03 AM
SouthernG35
Yes a $60.00 code reader was one of my first buys after I had my kit installed. I get P0300, P1284, and P1273. The P0300 stay's with me pretty much all the time. I am starting to think of it as just a driving partner
Old Apr 1, 2008 | 10:18 AM
str8dum1's Avatar
str8dum1
^ have you ever closed the gap on your plugs? I assume you are 1 step colder. Are they copper or iridum?
Old Apr 1, 2008 | 10:41 AM
SouthernG35
No I just started getting the P1284 and P1273 in the past few days. It is a a/f bank 1 and 2.
The plugs that I have are two step colder iridum I think. It is the ones that JT installed at PF when he installed the kit. So you think that the gap may need to be adjusted?
Old Apr 1, 2008 | 11:19 AM
str8dum1's Avatar
str8dum1
well that p0300 could def be caused by too cold a plug (why would u go with 2 steps colder?) or by too big a gap.
my motor used to miss a ton, reduced the gap, no more miss. Running too rich can cause you to miss as well.
good luck on the other codes. they def seem turbonetics specific.
Old Apr 1, 2008 | 12:27 PM
taurran's Avatar
taurran
Jeremy sells and installs NGK Copper 1-step colder plugs on his cars unless you brought or specified other plugs.
Old Apr 1, 2008 | 12:40 PM
SouthernG35
I just looked at my invoice from JT and my plugs are NGK LFR6A-11's . So taurran you are correct.
Old Apr 1, 2008 | 01:42 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Wrong these codes can be subject in any FI on the VQ35. If you search you can find threads in the FI section.
Old Apr 1, 2008 | 05:13 PM
str8dum1's Avatar
str8dum1
if you search, the only ppl complaining of these P1284 and P1273 codes own turbonetics......
https://my350z.com/forum/search.php?searchid=5875696
Old Apr 1, 2008 | 06:59 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
I've seen those same codes come up on other FI cars myself and having that code reader on me all the time everyone asks me for help. To say ONLY TN gets them is false.
Old Apr 1, 2008 | 07:22 PM
MIAPLAYA's Avatar
MIAPLAYA
Agreed. I believe QuadG35 had the same issues even when switching to a Greddy. Tons of F/I VQ35 cars get these codes. Only way I have seen them gone is with a standalone and GTM ECU flash..
Old Dec 7, 2008 | 01:37 PM
tylerxfire's Avatar
tylerxfire
old thread i know, but i am about to be boosted i have turbonetics kit, but not sure if it will be going on or another, and i have been reading all about check engine lights and others coming on. . I can't have this, why are the lights actually on, it seems like if you bought a kit from turbonetics say and had their reflash it would not be on if it was all right, same for any other company. . How do i get around ever having any codes show up because i won't be able to get inspected when the time comes with lights on.
