Vortech cog belt
Old Apr 3, 2008 | 12:08 PM
05Z33's Avatar
05Z33
Default Vortech cog belt
If I add a 34 tooth cog pulley to my non revup do I need to get a different belt, or is the stock belt going to be ok? I know that there is a tension pulley between the two cog pulleys. Will it just have to be adjusted? Also the non revup and the revup have different belts. Thats whats making me wonder about this.
Old Apr 3, 2008 | 06:13 PM
05Z33's Avatar
05Z33
Come on I know someone here has a 34/28 cog setup on their Vortech. What belt are you using?
Old Apr 4, 2008 | 04:20 AM
jpc350z's Avatar
jpc350z
I didn't have to use a different belt..
Old Apr 4, 2008 | 05:50 AM
jouvert00's Avatar
jouvert00
Same cog belt here as well...
Old Apr 4, 2008 | 06:15 AM
jouvert00's Avatar
jouvert00
Bando also makes a cog belt for the vortech, i just recently intalled it and seems to be more than capable.
Old Apr 4, 2008 | 05:53 PM
JCstart's Avatar
JCstart
can you use the 3.125 pulley with the 34 or 28 cog pulley ?
Old Apr 7, 2008 | 12:56 PM
eez's Avatar
eez
edited
Old Apr 16, 2008 | 08:00 AM
eez's Avatar
eez
dont run the belt over the top of the pulley. It will just shred the belt. I went back to the 560mm and I'm getting the tension pulley milled down on the sides so i can get some more tension.
350Z_Al
Oct 29, 2020 07:44 PM
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
