Is this too kinky? (Vortech oil feed line)
Old Apr 7, 2008 | 08:58 PM
JonnyC's Avatar
JonnyC
Default Is this too kinky? (Vortech oil feed line)
Everyone stresses that the oil feed line should have no kinks at all - is this too much of a bend or will it be fine? It's hard to see in the picture, but it bends toward the camera quite a bit coming off of the 90 degree fitting.
Also, pretty stupid question to ask now, but will I be fine with the feed line hooked up to the sandwich plate? My used kit didn't come with the T adapter off of the oil pressure sensor, and thought it was kind of ghetto anyways, so I decided this was a better way of doing it.
Thanks!
- Jon
Old Apr 7, 2008 | 09:11 PM
str8dum1's Avatar
str8dum1
thats fine. steel braided wont kink (under normal diameter bends anyhow..)
350Z400rwhp's Avatar
350Z400rwhp
It's the return line that needs to be straight as possible. Are you returning into the spacer or the upper pan?
Old Apr 7, 2008 | 09:38 PM
JonnyC's Avatar
JonnyC
Upper pan - just drilled and tapped that tonight. I'll make sure that the hose isn't kinked when I put the blower in.
Thanks guys. So I'm good running the feed line out of the sandwich plate?
Old Apr 8, 2008 | 06:00 AM
05Z33's Avatar
05Z33
Thanks!
- Jon
Wouldn't you get a better oil supply into the feed line by having the feed line lower in the oil pan? Also do you plan on installing an oil cooler
Old Apr 8, 2008 | 07:29 AM
JonnyC's Avatar
JonnyC
Well, you can't hook up a feed line just anywhere - it has to be post oil pump so there's some pressure
I don't plan on installing an oil cooler - already spent too much money. I won't be tracking this thing, and I'll have 6 quarts of oil so I should be fine. Have a temp gauge though, so if it gets bad i can always install one. Double sandwich plates, yeah!
Old Apr 8, 2008 | 07:35 AM
thawk408's Avatar
thawk408
Your oil feed line is fine. The sandwhich plate is fine also. Anywhere in the oiling sytem that has pressure is good.
Old Apr 8, 2008 | 07:48 AM
JonnyC's Avatar
JonnyC
Cool, thanks!!
Old Apr 8, 2008 | 07:49 AM
05Z33's Avatar
05Z33
This is good to know. I just ordered a oil filter sandwich the other day, so I think I'll also take this route.
Old Apr 14, 2008 | 12:00 PM
eez's Avatar
eez
that is where i ran mine. Much better than the stock location with the extra connections. I used the Greddy and used 1 port for oil feed and the other for the oil temp sensor.
Old Apr 14, 2008 | 12:44 PM
SpoilsofWar's Avatar
SpoilsofWar
Can you explain why its "better" then T'ing off at the stock pressure sensor port? I would think it would be exactly the same. Unless it was just somehow more convenient for you to source it there.
Old Apr 15, 2008 | 06:30 AM
GreenGoblin's Avatar
GreenGoblin
I think it make for a cleaner install but not better.
Old Apr 15, 2008 | 06:46 AM
eez's Avatar
eez
It's much easier to get a tight connection off the sandwich port. You don't have to use a T connector so there are less points to leak. I don't think it makes any difference on the oil feed itself.
Old Apr 15, 2008 | 06:47 AM
eez's Avatar
eez
cleaner = better
Old Apr 15, 2008 | 08:55 AM
Chudson coupe's Avatar
Chudson coupe
When I was installing my kit, someone stated that using the sandwich plate was a bad idea. He said that the oil supplied from there would not be filtered yet, while the line coming out of the stock sensor is filtered already (you want freshly filtered oil going to whatever FI you are running). I'm already T'd into the stock sensor port, but can anyone validate this as it may be helpful?
Old Apr 15, 2008 | 09:11 AM
eez's Avatar
eez
damn maybe it's not filtered. Looking at the service manual diagrams, I don't think the pressure port is filtered either.
could get one of these to be safe http://www.vortechsuperchargers.com/...p=70&cat_key=7
Old Apr 15, 2008 | 11:04 AM
JonnyC's Avatar
JonnyC
Hmm....crap, that sucks that it's not filtered. Hopefully someone can confirm if the oil pressure port is filtered? If it isn't, then no biggie. But I don't want to be running unfiltered if if it was designed to be run from a filtered location.
Old Apr 15, 2008 | 11:26 AM
Chudson coupe
Finally I contribute, score for me.
But if the pressure sensor doesn't have filtered oil I can't see it being a big deal if you use the sandwhich plate, so many people run off the pressure sensor port and don't have problems.
Old Apr 15, 2008 | 11:37 AM
thawk408's Avatar
thawk408
It is filtered. One of the ports come right out of the filter....
Old Apr 15, 2008 | 12:32 PM
JonnyC's Avatar
JonnyC
Ahh crap. Well...do I worry about it then? Or do I order the T fitting from Vortech and go that route? I've ordered too much crap from them already, but it'd be cheaper than screwing up the blower.
