Is this too kinky? (Vortech oil feed line)
Old Apr 15, 2008 | 12:39 PM
eez's Avatar
eez
Originally Posted by thawk408
It is filtered. One of the ports come right out of the filter....
Old Apr 15, 2008 | 01:16 PM
JonnyC's Avatar
JonnyC
^ Yeah, that didn't make sense to me either.
Does anyone know for sure if the oil pressure sensor port is pre or post filter? Unfortunately I won't be able to look at it until this weekend, but i'm thinking it's pre.
Old Apr 15, 2008 | 01:24 PM
05Z33's Avatar
05Z33
My sandwich plate has 4 ports and none of them are filtered. This would be a good time to hear from some of the install shops on here about this. Where are they running their oil feed lines from?
Old Apr 15, 2008 | 01:34 PM
eez's Avatar
eez
I don't see how the sensor port would be filtered
Old Apr 15, 2008 | 01:49 PM
05Z33's Avatar
05Z33
Does the sensor port lead into the ring that surrounds the oil out port?
Old Apr 15, 2008 | 04:08 PM
thawk408's Avatar
thawk408
Yal are way overthinking this. ALL the oil is filterd. The sandwhich plate oil will get filtered, but the sensor port is post filter. The oil goes from the pick-up screen, to the oil pump, then RIGHT to the filter. Then the oil is displaced through the motor, starting with the bottom ports and bearings. So, yes it will get filtered but the sensor port is probably better as it is post filter. If you are that worried about it, u can use some small inline filters on the feed line, just be sure to check them.
Old Apr 15, 2008 | 04:47 PM
markcearley's Avatar
markcearley
I just finished my vortech install a couple weeks ago. You might be surprised how small the brass orifice is at the oil inlet fitting of the super charger. Just got back from measuring the one I twisted off during install. .035" opening. Very easy to clog. I would make sure that line hasn't picked up any debris waiting to be installed. Yes the brass fitting at the oil inlet is easy to over torque and twist apart. After ruining the first one I asked vortech for a torque spec. They said there wasn't one, "just barely tight enough not to leak was the answer I got. BTW massive props to Sharif @ Forged Performance, Great Tune, Great To Work With!!
Old Apr 15, 2008 | 04:50 PM
markcearley
JonnyC, just noticed you mentioned UR crank pulley. Isn't that going to under drive the supercharger? IE lower boost at a given engine RPM.
Old Apr 15, 2008 | 04:57 PM
thawk408's Avatar
thawk408
If its the same diameter, no.
Old Apr 15, 2008 | 06:42 PM
Chudson coupe's Avatar
Chudson coupe
I'm not too familiar with the vortech, but I would be most concerned about warranty issues. If you don't install like the directions say, and use a sandwich plate, does it void anything?
Old Apr 15, 2008 | 06:49 PM
JonnyC's Avatar
JonnyC
It's a stock size pulley - just light-weight. My crank pulley was so rusty and ugly, I figured I might as well upgrade
Ok, from that picture it looks as though the pressure sender port is pre filter. Phew, no more parts to order - I'll stick with the sandwich plate.
Thanks for the pic!
Sleeper_Z
Sep 30, 2015 10:25 AM
