Snow performance vs Coolingmist Vari-cool
Old Apr 21, 2008 | 07:11 AM
XKR's Avatar
XKR
Originally Posted by westpak
I am going to install, someday, the Snow performance MAF kit which can be triggered by the Fcon rather then the boost controlled kit.
Thats the setup FP is doing for me. I feel safe with the Fcon running things.
Old Apr 21, 2008 | 07:12 AM
JonnyC's Avatar
JonnyC
Is there any place to fit the Snow tank in the engine bay? Or would it just be better to move the low-level switch into the wiper fluid tank and use that as the reservoir? I think i've used my wiper fluid twice anyways - this thing almost never sees the rain. I just don't want to have to run water lines all of the way from the trunk.
Old Apr 21, 2008 | 07:36 AM
westpak's Avatar
westpak
SFZCC
yeap it is nice, you can use the Fcon to trigger the voltage to the Meth kit and this triggers the additional maps and by hooking up the low level sensor it will prevent those maps from kicking in if low on Meth
Old Apr 21, 2008 | 07:37 AM
athenG's Avatar
athenG
Doesn't your windshield reservoir has a low level indicator that lights up in your dash when low? I know the G35 has them.
Old Apr 21, 2008 | 07:53 AM
JonnyC's Avatar
JonnyC
I'm not even sure - I'll check it out when he head home this weekend. That would be pretty nice though.
Dammit - I have to stop thinking about spending more money! Sometime down the road I might get it...I just need to get it up and running first, haha.
Old Apr 21, 2008 | 07:58 AM
athenG's Avatar
athenG
I think it is well worth it!! It gives you that peace of mind just in case you overboost, weather is real hot and in case you get a bad gas in your tank You can also tune aggressively if you choose too else just an added safety.
Old Apr 21, 2008 | 08:06 AM
JonnyC's Avatar
JonnyC
yeah, I would do it just for added safety off the bat. I'm going to be street tuning for quite a while, mainly just for AFR. I'm going to be using a conservative timing map (TXS TN map) and maybe play around with it a bit until I can get on a dyno.
Would it be alright to tune conservative w/o meth and then install the kit for added safety, w/o advancing any timing? I assume I'll get slightly less power, but cooler temps.
Old Apr 21, 2008 | 08:14 AM
D350Z10's Avatar
D350Z10
The 350z has a indicator light that shows low windshield washer fluid. As for the methanol resivor, I suggest running it in the trunk. And run an extra line out to your windshield washer fluid resivor for added safety. You guys are making to big a deal of this, just check it every time you run your car... it DOES NOT run out fast.
frankie945's Avatar
frankie945
Install pic's in the DIY section of the snow performance stage II kit I did last weekend.
Old Apr 21, 2008 | 08:56 AM
Z_boy912's Avatar
Z_boy912
do you guys use the nozzles that comes with the snow kit? what size are they?
where is a good place to get the snow performance stage 2 ?
Old Apr 22, 2008 | 02:03 AM
Z_boy912's Avatar
Z_boy912
question for the guys who have the snow performance kit and have the reservoir mounted in the trunk, do we need to buy the Solenoid Upgrade? (http://www.snowperformance.net/product.php?pk=20)
and is it worth it to get the low level indicator listed on snow website? (http://www.snowperformance.net/product.php?pk=16)
Old Apr 22, 2008 | 05:35 AM
athenG's Avatar
athenG
If you call Snow they will say it is a MUST if you are doing a trunk mount but Sharif did one without and said it works ok... Snow said that the problem will arise when you part your car on an incline.
Old Apr 22, 2008 | 06:20 AM
JonnyC's Avatar
JonnyC
It will come with whatever kit you buy (says it right in the description).
Old Apr 22, 2008 | 06:25 AM
cmtech1's Avatar
cmtech1
PM import image for deal on any of our Vari-Cool kits. They have some crazy deals going on.
To help answer your question, the trunkmount kit has a large capacity and has to be the easiest kit to install. Since the pump mounts in a recessed cavity in the tank its simple to install.
If you compare our underhood kit to our competitors you will see where the extra $60 comes from, the 1 gallon tank (vs 3 quart), ability to run multiple inputs, tuneability, all nickel plated fittings (vs plastic fittings).
contact josh at Import Image, I bet he gets you a killer deal.
CM
Old Apr 22, 2008 | 06:27 AM
350Z400rwhp's Avatar
350Z400rwhp
You only the need solenoid if the reservoir is above the spray nozzle. The reason for this is that gravity will force the water / meth out the nozzle. Secondly, I am using -20 degree washer fluid and making my own mixture by adding HEET (99% meth) from Walmart, I end up with about a 35% meth to water mixture and I am using my washer tank so I can use this on my windows too and share both my Snow Kit and Washer pump for my wipers from the same reservoir. The mixture I am making costs $4.25 per gallon. I buy a gallon of -20 degree washer fluid (which is about a 20% meth to water mixture). I then take out 24 ounces of washer fluid and add 24 ounces of HEET (99% Meth). Shake for good measure and then fill up my 1+ gallon washer reservoir.
Old Apr 22, 2008 | 06:44 AM
athenG's Avatar
athenG
+1 So you really need to mount the tank very low that your nozzle location is higher. Still there still a chance that it might leak if you are parked in an incline/decline so the extra Solenoid is good to have... we are not talking about an expensive part here...
Old Apr 22, 2008 | 07:22 AM
XKR's Avatar
XKR
Old Apr 22, 2008 | 08:03 AM
  #38
Z_boy912's Avatar
Z_boy912
can someone confirm weither the low level indicator already comes with the snow kit or you have to buy it seperatly?
Old Apr 22, 2008 | 08:06 AM
  #39
athenG's Avatar
athenG
Why not just call them and get the info straight from them... I doubt it is included since those are really upgrade parts.
Old Apr 22, 2008 | 08:16 AM
  #40
westpak's Avatar
westpak
SFZCC
I had to buy it separately
