Quick question about boost controller install.
I have everything hooked up other then the fuel pressure regulator vac line.
Does the line T into the hose coming out of the bottom of the FPR? (going to the right in the picture) or is that a fuel line?
If not, where does it go?
Figure it's better to ask then to spray fuel everywhere =)
ya, don't cut that one for vacuum, or you will have fuel everywhere. been so long since i have seen a stock fuel system, but iirc that is just a pulse modulator to make pressure more even, not like a typical fpr.
look at the front of the intake on the pass. side. there is a port there to tie into.
Originally Posted by jeffie7
Don't want to use that one since my map sensor and blow off use that.
You can make get some brass fittings to make a T to go on the large hose on the manifold in that picture. You need a 1/8" NPT female T fitting, three 1/8" NPT nipples, two that match the diameter of the OE hose and one that matches the diameter of the hose going to your waste gate and bost controller. Use teflon on the fittings. Autozone shoud have these fittings behind the counter.
I just need to install my PL block, I have one but was going to wait for Dave (FT) to do a one over on the car, before then I wanted to hook it up,
so bottom line, while the directions from HKS say to use the FPR, I can use any of the vac lines coming off the intake?
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
