Driving with my Vortech and the cog belt removed?
Old Apr 25, 2008 | 11:50 AM
350Z400rwhp's Avatar
350Z400rwhp
Default Driving with my Vortech and the cog belt removed?
I am driving to Forged next week from Ohio for tuning, I think it is about 600 miles. I plan on driving with no boost as this was recommended by Sharif. He sent me a base map to get my injectors running and all too. What is the best way to do this? Remove the cog pulley and let the air go through the supercharger, intercooler and all the plumbing? Should I somehow bypass the supercharger and put an airfilter on my intake tube? Lastly should I hook up my oil feel and return lines even if the supercharger is not spinning? Advice on this would be much appreciated. Thanks in advance.
Old Apr 25, 2008 | 12:00 PM
sentry65's Avatar
sentry65
the burninator
just take off the cog pulley
Old Apr 25, 2008 | 01:24 PM
350Z400rwhp
Do you mean pulley or can I just take off the cog belt? What about the oil feed and return should I have oil flowing through the supercharger if it is not spinning?
Old Apr 25, 2008 | 01:33 PM
sentry65's Avatar
sentry65
the burninator
sorry, taking off the belt is what I meant, not the actual pulley
if the blower isn't turning and thus not creating any heat, it doesn't need oil to cool it
Old Apr 25, 2008 | 01:34 PM
booger's Avatar
booger
The oil will go thru the SC and return to the motor just fine . I drive mine all the time with out the blower belt on in the winter . To get the best air flow , disconnect the IC pipe that runs down behind the blower . I just cut up a cheap furnace filter and clamp it over the end of the IC pipe
Old Apr 25, 2008 | 01:53 PM
350Z400rwhp
So basically the air only travels through the filter the the maf sensor the throttle body and in the engine just like a n/a intake or stock. The air does not flow through the supercharger head unit and through the intercooler and all. This is the way I was leaning towards if so.
Old Apr 25, 2008 | 04:06 PM
350Zzzz's Avatar
350Zzzz
Professional
My engine was knocking when the Procharger FMU shorted out, I was returning from Maine at 12 midnight driving through New Hampshire when it happened. Removed the cog belt and drove home to Stamford without a hitch.
Safe trip
G
Old Apr 25, 2008 | 05:33 PM
JonnyC's Avatar
JonnyC
Yeah, that's if you disconnect the up-pipe that runs behind the blower and put a filter on. If you keep all of the piping hooked up, you will be sucking unfiltered air in through you bypass valve - so either rig up a filter for that or get the BPV filter from superchargersonline, or i think you can just disconnect the vacuum line from it so that it stays shut and sucks air in from the blower (just be sure to plug the vacuum line going to the FMU/intake manifold).
Old Apr 25, 2008 | 07:23 PM
booger's Avatar
booger
I have found that the car doesnt run so rich when you disconnect the up IC pipe behind the blower and put some type of filter on it . Much better air flow , than sucking air through all that piping and the IC
Old Apr 25, 2008 | 11:20 PM
350Z400rwhp
Thanks for all of the input guys. I am just going to rig up an air filter and bypass the whole thing. I'm sure either way is fine though. Thanks again!
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
