Coolant Purge Nightmare
Old Sep 27, 2009 | 04:46 PM
  #41
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Originally Posted by viva la spam
i followed these directions and purged my Z numerous times. what else could cause the car to overheat. oil level is correct and im not having any ses or lights come up. someone mentioned i couldve blown a headgasket. say it aint so.....
How far are you from Tulsa OK? I'd be happy to take a look at it if you'd like.
Old Sep 27, 2009 | 05:02 PM
  #42
doug's Avatar
doug
https://my350z.com/forum/7695799-post35.html
https://my350z.com/forum/forced-indu...erheating.html
Old Sep 27, 2009 | 05:03 PM
  #43
ImWeeZzel's Avatar
ImWeeZzel
Originally Posted by - bigc -
do you get HOT air when you turn your heater (fans, but no AC) up to 90 when you first get in the car?
takes it about 10 min, yes
Old Sep 27, 2009 | 05:14 PM
  #44
- bigc -'s Avatar
- bigc -
you should get hot air pretty quickly without revving the engine. it sounds like you may still have some air in your coolant system.
Old Sep 28, 2009 | 06:05 AM
  #45
ImWeeZzel's Avatar
ImWeeZzel
i read those forums but didnt look at the picture carefully enough to see that the filler has a connector for the radiator cap. if it worked for all the other guys ill give it a shot. thanks for the support guys. ill keep ya'll updated
Old Oct 1, 2009 | 04:49 PM
  #46
ImWeeZzel's Avatar
ImWeeZzel
id like to thank everyone who made this thread a success. the leslie funnel thing work like a charm in the second try. no more overheating and my car is back on the road. she was 2quarts low! someone on this site once said "its good to see happy endings other than in a spa for +20 dollars lol
keep up the good work
Old Oct 2, 2009 | 08:57 AM
  #47
doug's Avatar
doug
oh me love you long time
Old Oct 3, 2009 | 04:12 PM
  #48
BrazenZ's Avatar
BrazenZ
Better late than never,
I too was having difficulty with engine overheating and spraying the green stuff on my engine hood. If you have performed the "Pathfinder cooling mod" you no longer have that little valve to bleed air out of your coolling system. A friend recommended that I go a dealership and have my radiator put on a vacuum and suck the air out. They do this to BMW's all the time. It cost $45, no fuss no mess.
Old Oct 3, 2009 | 06:23 PM
  #49
Zivman's Avatar
Zivman
Originally Posted by BrazenZ
If you have performed the "Pathfinder cooling mod" you no longer have that little valve to bleed air out of your coolling system. .
not true....
the bleeder has nothing to do with cooling modification. You have the APS TT which means the 'T' that has the bleeder in it was removed and replaced with a 'T' that feeds the LHS turbo with coolant. Due to the difficulty of purging the system, if your installer was smart, they would have left the bleeder alone and resplit the line to install the feed to the turbo.
Old Oct 7, 2009 | 11:16 AM
  #50
BrazenZ's Avatar
BrazenZ
Originally Posted by Zivman
not true....
Maybe am using the wrong terminology, but the purge valve on passenger side cooling pipe that connects to cast aluminum part that carries fluid from Bank 1 to Bank 2, When you do the "pathfinder mod" you must cut the valve off the cooling pipe and replace it with a short rubber hose.
Old Oct 7, 2009 | 11:27 AM
  #51
doug's Avatar
doug
i have the pathfinder cooling mod and still have the valve in the same place
Old Oct 7, 2009 | 11:38 AM
  #52
BrazenZ's Avatar
BrazenZ
Crap, I read the directions wrong again
Old Oct 25, 2009 | 11:00 PM
  #53
ashan723's Avatar
ashan723
I have a question. If you have air in the coolant system, does this cause to leak coolant at the bottom of the radiator after a drive? If I just need to bleed the system, this will save me money on buying a new radiator, which I thought was going to be my solution. Thanks.
Old Oct 25, 2009 | 11:09 PM
  #54
binder's Avatar
binder
no, your radiator is leaking so it has nothing to do with air in the system.
Old Oct 26, 2009 | 05:43 AM
  #55
ImWeeZzel's Avatar
ImWeeZzel
if you do get a new radiator look into mishimoto imo but other aluminum radiators are a plus. it could be a leak in your lower hose? start w/ the small details first
Old Oct 26, 2009 | 10:25 AM
  #56
ashan723's Avatar
ashan723
Thanks binder and viva. I checked my hoses lower and upper and no leak from there. I am thinking of getting a new radiator and I came across koyo, mishimoto, and megan. megan is the cheaper one of the three. Is megan an ok brand to get or should I spend an extra $60 for the mishimoto? Thanks.
Old Oct 26, 2009 | 10:29 AM
  #57
- bigc -'s Avatar
- bigc -
get the koyo - new v-cores go for about $300 these days and there are at least 2 used ones in the marketplace right now. as for the mishimoto one, it will work fine, but i've heard some bad stories about its fitment. i've heard nothing about the megan radiator (didn't even know it existed )
Old Oct 26, 2009 | 01:45 PM
  #58
ashan723's Avatar
ashan723
thanks. I learned a few new things from this forum. yeah, I read something on another forum implying that mishimoto are knock offs or something like that. I came across megan while searching on the market place. I got koyo replaced into my car today. hopefully comes out good and will bleed out my coolant system just to try it myself. the mechanic probably did it for me already, but will go ahead and do it anyways. thanks again to all.
Old Oct 26, 2009 | 07:56 PM
  #59
ImWeeZzel's Avatar
ImWeeZzel
mishimoto does require minor tweaking to be honest. i removed the rubber stoppers underneath the oem radiator and shaved them down w/ a pocket knife, then it fit just fine. as for being a knock-off, uh i strongly doubt that. they are a well known brand and excellent customer service. just ask any one of us w/the mod. i found some cheap ones when i went shopping but i didnt want an aftermarket radiator w/ plastic parts. these guys are knowledgeable when it comes trouble shooting. make sure there is a warranty
Old Oct 26, 2009 | 07:58 PM
  #60
ImWeeZzel's Avatar
ImWeeZzel
by these guys i mean those of you who contribute to the forums w/ solutions. smart *** replies are exception, but only if funny...lol
Chris350z03
Oct 8, 2023 07:19 PM
SharX59
Sep 27, 2015 09:23 AM
EnjukuRacing
Sep 18, 2015 07:57 AM
smithmt3
Sep 11, 2015 08:25 PM
