Code PO345 CAM Sensor CODE?!!
Old May 11, 2008 | 08:13 PM
jvargas714's Avatar
jvargas714
Default Code PO345 CAM Sensor CODE?!!
Well i've had my 05 vortech supercharged 350z with the ss box for about 5000 miles, and just a couple of days ago i had trouble starting my car. It would crank for a few seconds before finally turning over, and now i have SES light WTF!! this came out of no where. Anyway i brought the car down to my local auto parts store and read the codes and it turns out that the only code that came up is P0345 which is a camshaft position sensor A bank 2 circuit malfunction . I have located the sensor that the code calls for but am not sure if i wanna go ahead and change it out, i dont wanna be chasing this problem by changing a bunch of parts and spending a whole bunch of cash when the problem could have been caused by something real simple. I just wanted to know if anyone had any advice or have had similar problems. Any help at this point would be great. Thank you in advance to those who can offer some help.
Old May 12, 2008 | 09:29 AM
350 Rookie's Avatar
350 Rookie
Do you have a volt meter. You gotta do a voltage test on the sensor and look at the specs on the service manual. if its within specs, its good and its somethin else. If its out of spec, then replace it.
Old May 13, 2008 | 06:13 AM
jvargas714's Avatar
jvargas714
thanks for the advice. Yes i do have a voltmeter and ill go ahead and look up the specs on what i should be metering. ill see if this can shed any light on whats goin on.
Old Sep 15, 2008 | 10:25 AM
ADMAN's Avatar
ADMAN
Any news on this???
2ndchanceZ
Oct 26, 2015 08:03 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
