HKS 1000cc injector, idle
Old May 15, 2008 | 03:36 PM
GTM's Avatar
GTM
Vendor - Former Vendor
Np, Oh yea and to fix your utec issues.....
Get a standalone
j/k
-George
GTM
Old May 15, 2008 | 03:41 PM
frankie945's Avatar
frankie945
Cool
what ever you say
Old May 15, 2008 | 04:28 PM
westpak's Avatar
westpak
SFZCC
Originally Posted by George@GTM
My car idles like stock with the HKS 1000cc Injectors and HKS FCon VPro, so there is no need to "downgrade" your injectors.
It is tuning related.
-George
without an ECU reflash for idle?
Old May 15, 2008 | 04:45 PM
al_v's Avatar
al_v
Originally Posted by frankie945
I have 600 deatchwerks my idle is a little rough When warm the idle go's up & down a bit I hate it.
I have the same problem with the Utec and rc 550cc injectors , I think the problem is the idle speed , the ECU is trying all the time to reduce the idle speed , and the bigger injectors doesn´t help too much , I´m thinking in raise the idle speed to 800-850 rpm , to check if the problem continuous or not.......
Old May 15, 2008 | 04:55 PM
Nexx's Avatar
Nexx
never had an issue with my old utec and rc550's.
Old May 15, 2008 | 05:04 PM
al_v's Avatar
al_v
Hmmmmmmmm , maybe you didn´t have a 3.5 bar FPR......
Old May 15, 2008 | 05:13 PM
Old School's Avatar
Old School
Shift_Boost
utec and 750s here...perfect idle.
Old May 15, 2008 | 07:41 PM
Jay'Z's Avatar
Jay'Z
Reflash fixed my idle issue..
Old May 15, 2008 | 09:05 PM
SlideFox's Avatar
SlideFox
Standalone FTW!
Old May 15, 2008 | 09:20 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Like everybody says, it's tuning related..
I just got mine tuned. It's smoother than stock I swear! I have HKS 1000cc, F con v pro, GTM ECU reflash and GTM stage 2 turbo cams (272s).
Old May 16, 2008 | 02:07 AM
westpak's Avatar
westpak
SFZCC
but there you go saying you have the reflash so it it is not just tuning then.
can someone explain what is in the reflash???
I have pm'd GTM twice over the last few months for an explanation for the flash to see if it will help me, I also have the hunting idle at times and can only assume that it is the ECU trying to find an idle which it can't since it is only controlling the throttle and not the fuel. So I don't think it is completely tuning related if at one point the idle will sit around 950 and steady and then at other times it hunts bouncing between 900-1100
Old May 16, 2008 | 04:15 AM
ML2000's Avatar
ML2000
Originally Posted by westpak
but there you go saying you have he reflash so it it is not just tuning then.
I have pm'd GTM twice over the last few months for an explanation for the flash to see if it will help me, I also have the hunting idle at times and can only assume that it is the ECU trying to find an idle which it can't since it is only controlling the throttle and not the fuel. SO I don't think it is completely tuning related if at one point the idle will sit around 950 and steady and then at other times it hunts bouncing between 900-1100
+1, I would really like to know some details also, I may have to include this reflash in my future plans.
Old May 16, 2008 | 06:32 AM
captj3's Avatar
captj3
Chances are no shop will respond to answer the question what do they do to fix the problem or what they do for the reflash. That goes against them making money. Just give us the car and we will fix it send us money you don't have to know what we are doing. Great support for the community.
Old May 16, 2008 | 07:00 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
If you search it, you will find out that Sam mentions switching closed loop idling to open loop idling in order to control the idle better with F con v pro. That's pretty much only thing I know about the GTM reflash. He also did some fancy things to prevent CEL, VDC, SLIP lights from coming on with F con v pro.
Old May 16, 2008 | 01:55 PM
westpak's Avatar
westpak
SFZCC
thanks, I guess I will try calling them since PM's go unanswered and see what they can do on a reflash to take care of this idle, and see what else they offer on the reflash, I currently don't have any other issues with CEL's
Old May 16, 2008 | 11:41 PM
clemlover15's Avatar
clemlover15
bump 4 more info on the reflash
Old May 17, 2008 | 12:55 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Default Gtm Spec Ecu Flash
From Our Web site
http://www.gtmotorsports.com/product...cat=487&page=1
Our GTM Spec ECU flash will eliminate any unnecessary check engine lights commonly found when upgrading to a standalone, but does not remove the important codes so they still come up if a problem were to occur. it also stabilizes the idle and eliminates idle hunt especially when using upgraded high lift cams ,This is accomplished by having full control over the ECU and making it stay in open loop during idle, We also adjust the rev limiter, speed limiter, Idle RPM set point, and remap the Throttle Control for better response.
GTM Spec ECU Features List
Top Speed Limiter
Rev Limiter
Idle RPM
Target AFR
Ignition Timing
Electronic Throttle Control
Open /Close Loop Control
Cam Phasing
Map Switching
SAM
GT MOTORSPORTS
Old May 17, 2008 | 02:33 AM
  #38
chopperman's Avatar
chopperman
$600 for a reflash, Do we just send in our ECU and then you guys reflash it? That seems like alot.
Old May 17, 2008 | 09:43 AM
  #39
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I sent my ECU from South Korea to Sam@GTM to get it...
Old May 17, 2008 | 09:57 AM
  #40
chopperman's Avatar
chopperman
Hey it would be cool to see your car some time, im stationed at camp Humphreys. I could always take a trip down to seol
