Brian Crower Stage 3's Preliminary test results are in!
Old May 20, 2008 | 03:12 PM
marques1's Avatar
marques1
interesting!!
Old May 20, 2008 | 03:14 PM
ForcefedZ's Avatar
ForcefedZ
Originally Posted by Julian@MRC
Shiiiiit...That would make 30+psi and kaboom!!lol
30+psi yes, kaboom no. What are the turbo rated to flow each?
Old May 20, 2008 | 03:19 PM
IIQuickSilverII's Avatar
IIQuickSilverII
(J correct me if i am wrong)
i think he is using the regular aps tt kit so its a gt25 turbo, so id say they flow to 270-300hp each
(not sure if this is the right gt25r chart)
Old May 20, 2008 | 03:21 PM
Julian@MRC's Avatar
Julian@MRC
(J correct me if i am wrong) i think he is using the regular aps tt kit so its a gt25 turbo, so id say they flow to 270-300hp each
Ok, your corrected..
APS extreme...More like twin GT30's.
Old May 20, 2008 | 03:24 PM
IIQuickSilverII
oh its the extreme kit, awsome! (is this Zonis car or yours?)
i guess its like about ~ 430-450hp each then
Old May 20, 2008 | 03:25 PM
Julian@MRC's Avatar
Julian@MRC
i guess its like about ~ 430hp each then
Mine.. Zoni's. Vinos..ect....
Old May 20, 2008 | 03:53 PM
ForcefedZ's Avatar
ForcefedZ
awsome 430-450hp each then
Now that would make this thread interesting.
At 30-32psi it's still 72% efficient. At best you got 100lbs/min which we'll yield you about 850rwhp. That would be 142rwhp a cylinder, which any decent connecting rod will take without breaking a sweat.
Surely you didn't install stock rods in your newly built knife edged crank engine so all should be good.
Big valve ported heads, built bottom end, supersizeego, I mean cams with some black magic voodoo MRC tuning on a Dyno Dynamics has got youtube written all over it!
Old May 20, 2008 | 05:26 PM
rrmedicx's Avatar
rrmedicx
Nice. If these cams were available for my build, I would have gladly used them.
Nice work. What size are the stage 3 cams 284's or something?
I think the Stage 2's were 272's right?
Old May 20, 2008 | 05:48 PM
thom000001's Avatar
thom000001
whenever i eventually do the cams, these will be the ones I go with.
Driver06's Avatar
Driver06
Nice comparison Julian.. these cams will be a part of my build
Old May 20, 2008 | 06:52 PM
Julian@MRC's Avatar
Julian@MRC
Videos of idle and reving..
Old May 20, 2008 | 07:12 PM
turismo's Avatar
turismo
Damn that sounds good. How much are these cams?
Old May 20, 2008 | 07:37 PM
Julian@MRC's Avatar
Julian@MRC
Last time I checked about $1100 range..Or so..Give me a shout tommorow, ill check pricing and stock.
Old May 20, 2008 | 07:46 PM
turismo's Avatar
turismo
Do you think these cams will pull to 8k rpms?
Old May 20, 2008 | 07:54 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
The Stage 2 cams are 264 duration and these Stage 3 cams are 272.
Old May 20, 2008 | 08:12 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Very interesting results and not what I was expecting to see! I expected to see substantial high end gains, but I'm surprised to see the power coming on sooner with such huge midrange gains. I thought that bigger cams typically push the powerband to the right?
Looking forward to a 14 PSI vs. 14 PSI comparison.
Old May 20, 2008 | 08:32 PM
Julian@MRC's Avatar
Julian@MRC
Ill be the first to know, you guys will be the 2nd..
Old May 20, 2008 | 08:34 PM
  #38
Julian@MRC's Avatar
Julian@MRC
Well the larger cam with the larger turbos, are allowing them to breath a bit better..Im thinking the lift is not the big factor as much as the duration...Were also not disregarding the fact that we had the crank knife edged, but I dont think that would make 70 ft lbs. itself...
Old May 20, 2008 | 08:41 PM
  #39
iamdigital's Avatar
iamdigital
nice results. looking forward to the limit pusher tests (8K RPMs). Also liking that growl!!!
Old May 20, 2008 | 08:43 PM
  #40
Julian@MRC's Avatar
Julian@MRC
Me too....Does it not sound like a V8??
