Brian Crower Stage 3's Preliminary test results are in!
Old May 18, 2008 | 02:12 PM
Julian@MRC's Avatar
Julian@MRC
Default Brian Crower Stage 3's Preliminary test results are in!
We finally got some dyno comparisons on the BC stage 3 cams!! To my knowledge, no one has done a direct cam to cam comparison on the Stage 2's to the Stage 3's...
The motor we used was the same motor, same turbo kit, same everything, with the exception of a new set of pistons and rings (same exact ones CP 8.5:1), and a knife edged crank. I guess scientifically one could say the tests results arent an EXACT comparison, but its the closest the community has to one.
The new rings were seated and brokenin on the dyno and road for about 40 miles, and we began to do some dyno pulls with a conservative base map tune. The A/F ratio hovered around 11.3 to 10.9 in the upper rpms, with mildly conservative timing. The last thing we wanted to experience was detonation on a new set of pistons.
Even with a very conservative tune and low boost level of 11psi (wastegate spring pressure) we manage to get the following results, and we were pretty amazed to say the least...
what we found is that at lower boost levels, we made 70Ftlbs of Tq more and 50 hp more at 4200 rpms!!This is some real drivable powerband that we felt like we were missing before with the APS extreme turbos.
If you lookat the two dyno charts, you can see that:
The RED is the old Stage 2 set up at about 14.5 psi.
The BLUE is the BC stage 3's at about 10.5-11psi.
We are confident that with more boost, the results will be amazing !!!! Stay tuned for more updates as we tune..
Old May 18, 2008 | 02:30 PM
ToastZ's Avatar
ToastZ
Julian,
How well do they idle ?
Looking good.
Old May 18, 2008 | 02:49 PM
thom000001's Avatar
thom000001
yea, what EMS and how do they idle?
Old May 18, 2008 | 03:17 PM
Julian@MRC's Avatar
Julian@MRC
fairly well idle actually..
HKS Fcon V Pro of course..
Old May 18, 2008 | 04:02 PM
turismo's Avatar
turismo
Nice. Are these in stock?
Old May 19, 2008 | 04:27 AM
ForcefedZ's Avatar
ForcefedZ
Interesting results with impressive gains. Not at all what I would've expected.
No adjustments were made to your ignition advance table and VTC? Same fuel? On the DD is there a way to compare the two runs without any correction?
I see you skipped the 1800 mile breakin
Old May 19, 2008 | 04:47 AM
QuadCam's Avatar
QuadCam
seems like they should switch the names.......call the stage 3 cams Stage 2, and vice versa.
The Stage 2s look like they are more of a higher rpm cam, while the stage 3 is more for a stock type powerband.
Old May 19, 2008 | 05:57 AM
rcdash's Avatar
rcdash
11 psi vs 14 psi? Keep in mind what the stage 3 will look like at 14 psi... Very nice comparo Julian.
Old May 19, 2008 | 06:05 AM
Philthy's Avatar
Philthy
Boost Junkie
Very promising results... VIDS bish!
Old May 19, 2008 | 06:53 AM
IIQuickSilverII's Avatar
IIQuickSilverII
idle rpms same as stock?, or is the stock ecu flashed to set it higher?
Old May 19, 2008 | 08:15 AM
QuadCam's Avatar
QuadCam
I realize that there was a psi difference. I was just noting how the power starts to lay down and go flat around 5800 on the Stage 3 cams. On the stage 2 cams, the power is still climbing when the dyno graph stops.
Old May 19, 2008 | 11:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
The stage 3 setup will be much faster. All the power down low, and its making good power to basically 7000rpm's thats plenty to get moving. Nice comparison, similar to my results (compared to S1's though) with the insane TQ coming on earlier, and staying longer.
Old May 19, 2008 | 03:21 PM
Julian@MRC's Avatar
Julian@MRC
The dyno of the Stage 2's had a perfectly tuned A/F and timing ratio...The Stage 3's are on a conservative break in tune.I assure you when we lean the A/F to above 10.8 and add normal timing up top, we will surpass the RPM range..Also keep in mind, your talking about only a 30whp loss from 5800-redline with over 3 PSI less boost..
Old May 19, 2008 | 03:25 PM
Julian@MRC's Avatar
Julian@MRC
No change to the VTC or ignition advance, if anything its a bit more conservative than the one I was running. As far as the DD corection thing, The both graphs were with the 13% DJ correction, so the gains were the same. The Atmospheric correction was actually at about .9787 on the day of the stage 3's, so it was pulling HP for the Atmospheric conditions.
I clould show a graph with the 2 of the pulls with a 0% correction to DD numbers, but the gains will still be gains in the same places..
Yeah, and we said F'it on the 1800 mile break in..
Old May 20, 2008 | 01:14 PM
Julian@MRC's Avatar
Julian@MRC
wow, thought this thread would get alot more replies...
Old May 20, 2008 | 01:57 PM
rcdash's Avatar
rcdash
It sucks that cool stuff always comes out a little bit too late!
How's that?
If I was building today... oh well. I would like to know more about idle quality - if you had to bump it etc. I have a stable idle at 750 rpms with my JWT S2 so can't complain about that at all...
Old May 20, 2008 | 02:15 PM
Julian@MRC's Avatar
Julian@MRC
How's that?
Idle is fine..Im bumped to about 850-900.
Old May 20, 2008 | 02:42 PM
ForcefedZ's Avatar
ForcefedZ
Pull the wastegate lines off and spin it out to 8500 rpm...That would be some good data
Old May 20, 2008 | 02:59 PM
Julian@MRC's Avatar
Julian@MRC
Shiiiiit...That would make 30+psi and kaboom!!lol
Old May 20, 2008 | 03:01 PM
IIQuickSilverII
thats what i was asking in post #10
thanks for the answer
