Install vortech full kit
Old May 19, 2008 | 04:38 PM
NH01's Avatar
NH01
Default Install vortech full kit
Mods on 03 Z
Kinetix V+ plenum
test pipe, + full exhaust..
mechanic just installed Vortech FULL kit (brand new)on my car..
he says the car looses boost and sputters around 4k rpm.
1.Is the kinetix v+ plenum compatible for this vortech kit? i think there is 1 less vacuum nozzle on it compared to stock? not sure anyway.
2.could it be the SS box connected wrong? is the diagram in the vortech install manual 100% correct?
help help help
Thanks
Old May 19, 2008 | 04:52 PM
frankie945's Avatar
frankie945
I would say vacuum leak some were. But let the Vortech guys chime in.
The kinetix v+ plenum is not a problem.
Old May 19, 2008 | 04:56 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Check for vacuum leaks and check and make sure the belt is tight.
Pics might help with you vacuum lines.
Old May 19, 2008 | 05:32 PM
NH01's Avatar
NH01
THanks guys
SS box problem fixed.. no more sputter.. jsut no boost now..
he's checking all the intercooler piping and couplers now. and will test run it again..
he says the stock couplers are crap.. they are just BARELY fit.. so most of them he changed them.
Old May 19, 2008 | 05:33 PM
booger's Avatar
booger
Check the aux. fuel pump to see if its coming on
Old May 19, 2008 | 05:34 PM
booger's Avatar
booger
Originally Posted by NH01
THanks guys
LOL I run the same stock hose clamps and run 22psi with my Vortech . The clamps are fine . Its the guy tightening them up !!!!
Old May 19, 2008 | 05:44 PM
NH01's Avatar
NH01
22psi! wow.. ahhaha
too much power for me lol..
7-8psi enough for me.. I will get a call back soon to see if its working properly before i go drive out and pick it up...
Old May 21, 2008 | 09:19 AM
NH01's Avatar
NH01
Default A/f
Hey all,
Full kit is in and working..=)
question:
I have the AEM wideband hooked up to the Y pipe... Anyway.. The readings I am getting now is SUPER RICH... when im hard on throttle the A/F is like at 10-11..wtf.. is that normal for the full kit? Can the SS box be tuned? there is a serial port on the side of it.
cruising at highway speed the A/F is around 14.6-15.2 so that is normal I beleive but just when ur hitting it hard the car is super Rich.. but still.. runs mint..the car freakin goes!
Thanks
Old May 21, 2008 | 10:04 AM
frankie945's Avatar
frankie945
Hey all,
question:
Thanks
you want to be in the low 11's like 11.4 11.6 in boost. I am at 14.6 to 14.8 on highway or just going 40 mph. It's better to be rich than lean... I am not firmilar with the ss box.
Old May 21, 2008 | 10:06 AM
jpc350z's Avatar
jpc350z
Hey all,
question:
Thanks
The kit is rich untuned..You should get it tuned with about 11-12 A/F at WOT.The S.S fuel map can be modified but requires the R4 software. Take it to a tuner familiar with the unit.. At cruise the A/F is controlled by the ECU and those A/F #'s are normal..
350Z_Al
Oct 29, 2020 07:44 PM
