Is this True. TP question!
Old May 28, 2008 | 08:29 PM
aguita's Avatar
aguita
Default Is this True. TP question!
I was told that TP on turbo car actually decrease the performance of the car..I currently have installed UTR resonated on a Greedy TT Z..I have Borla TD and I must admit that the car is quieter than before.when I was NA the car sounded more..no is quiet..Is this Caused by the TP? should I get a NON resonated? what about performance..
thanks
Old May 28, 2008 | 08:33 PM
Cannysage's Avatar
Cannysage
TP on your Greedy TT will not decrease your powah!
Also, how can your NA car sounded more.. no is quiet. It should be louder.
p.s
stay with the resonated tp.
Old May 28, 2008 | 08:43 PM
aguita's Avatar
aguita
I mean that the engine is louder but the exhaust is barely heared!..when NA the exhaust was louder...mayb im just paranoid?!
Old May 28, 2008 | 08:49 PM
Cannysage's Avatar
Cannysage
maybe the engine noise is overpowering the exhaust. also, your car's a lot louder from the outside. I let my buddy drive it, and my bov+everything is 2x louder.
Old May 28, 2008 | 09:00 PM
aguita's Avatar
aguita
so there's no way to solve this..??The borla Sound is delicious..but not anymore...I thought that getting a non resonated will solve the problem..soo i should stay with the res ?!
Old May 28, 2008 | 10:12 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
If you've gone TT, then that is why your exhaust sounds quieter. The turbos themselves act like a mini muffler. Whereas an NA car's exhaust just goes straight out.
And no your car wont loose power with test pipes. Maybe at very low boost settings, you want little bit of back prerssure purely for better torque, but you won't loose power.
Old May 29, 2008 | 05:15 AM
DanielW's Avatar
DanielW
^+1 turbos act as mufflers. hell my turbo is my ONLY muffler
Old May 29, 2008 | 07:16 AM
taurran's Avatar
taurran
thanks
Not true. The larger the unrestricted test pipe, the larger peak exhaust flow capability of the setup, which means more power.
An unresonated test pipe will provide slightly better flow than a resonated test pipe, but it will be louder.
Your borla exhaust is a bigger restriction than your test pipes.
issyz
Jul 2, 2017 03:04 PM
May 30, 2017 03:28 PM
Dymsi
Sep 29, 2015 11:32 AM
