--->jkenefic version 3.0 build<---
Old Apr 17, 2009 | 04:47 PM
  #181
DMK's Avatar
DMK
Bump!
jkenefic - Why didn't you go with HR Main Studs as well?
From the JWT pdf, does anyone know what Nissan Part#'s I need to do the Pathfinder cooling mod?
Old Apr 18, 2009 | 11:44 AM
  #182
MADScientist's Avatar
MADScientist
^^^ I would have, but already had the ARP mains purchased...
Old Apr 18, 2009 | 11:56 AM
  #183
Cass007's Avatar
Cass007
Originally Posted by DMK
Bump!
Just buy everything as a kit. I know Forged and several other vendors sell it.
Old Apr 19, 2009 | 06:14 PM
  #184
DanielW's Avatar
DanielW
so how are things holding up?
Old Apr 20, 2009 | 02:21 AM
  #185
DMK's Avatar
DMK
Well I can get the parts at cost from the Nissan dealer. I just need the part #'s.
Old Apr 20, 2009 | 05:15 AM
  #186
MADScientist
Everything is great so far! The car was put up for the winter and I am in the process of adding a few more parts
In the process I have been checking on everything and the motor appears to be in good health. Compression testing averaged 145psi per cyl and all of the plugs were in good shape gapped to .035" just like I left them. No coolant consumption either... Only thing that I am using a little bit of is oil, which is to be expected with this level of power output. Using as much methanol as I do when it mixes with the oil it breaks it down faster and causes a little more blow by. I did not have this problem until I switched to Mobile 1, so I am going right back to the 300V Motul, since the meth does not seem to break that down as easy or quickly.
Old Apr 20, 2009 | 09:29 AM
  #187
DMK's Avatar
DMK
^You using Mobil 1 15w-50?
Old Apr 21, 2009 | 07:38 AM
  #188
MADScientist
Yes, I was... Oil would just get contaminated faster than the 300V of the same weight. Hence more blow by than with the Motul in the same oil change frequency of 3000 miles.
Old Jun 23, 2009 | 05:09 PM
  #189
jining's Avatar
jining
So is there any more information besides the JWT .pdf about modifying a VQ35DE for the HR head studs/gaskest? I think I will be going this route soon with a budget bottom end build.
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
