--->jkenefic version 3.0 build<---
Old Jun 5, 2008 | 12:05 PM
  #141
QuadCam's Avatar
QuadCam
Originally Posted by DanielW
dumb question probably but where can I buy the HR headgasket besides from nissan? or is that the only place?
I just orded a set from my local nissan dealer......$32.00 per gasket and no shipping costs!
Old Jun 5, 2008 | 05:49 PM
  #142
Weqster's Avatar
Weqster
I think the key point here is not if L19 will provide more clamping force, but will that clamping force be applied evenly, consistantly, over the life of the engine. I think the TTY alternitive is a great way to garentee consistant clamping pressure.
The main difference and the reason why you cant compare the VQ to other platforms is that people never re-torque studs after heat cycles. I think it may be a reason why we get inconsistant resaults across all builds. I think the key here is preparation and expert installation of the head studs. I think it is a critical factor.
With hondas, we dont even get an L19 option. Standard arps have been used for upto 40psi of boost. Reliable as hell. Full alluminium open deck. But a recommend practice is a copper (spray) coated OEM gasket. I remmber the first headgasket i ever replaced, i used an aftermarket OEM style. Fresh ARP studs. That thing didnt even last the end of the street, instance head lift. Next time around i used a OEM gasket and copper coated it. Reused and aded a few more ft-lbs of torque to the ARPs. IT didnt headlift until i had holes in the pistons.
Old Jun 5, 2008 | 07:29 PM
  #143
DMK's Avatar
DMK
Wow, I can't believe I have missed this thread.
I have been planning on going the same route, HR Gaskets, Headstuds and even Mainstuds. I was turned onto the HR gaskets after being told about them by theHawk408. I also talked to Sharif who informed me he was working on a car with this proposed setup. It's good to know it is holding the power without a sweat. Would love to see some long term results in a couple months. Congrats.
Old Jun 9, 2008 | 12:06 AM
  #144
accordfreak's Avatar
accordfreak
thanks OP for this very informative thread!
Old Jun 18, 2008 | 11:33 AM
  #145
QuadCam's Avatar
QuadCam
I just picked up my HR head gaskets from the dealer. they are triple layer gaskets, with the middle layer only going around the cylinder perimeters. I assume that it makes for a higher pressure seal than the previous DE design.
Old Jun 18, 2008 | 04:00 PM
  #146
QuadCam's Avatar
QuadCam
Here's what the HR gaskets look like. I noticed that they have small holes in the inner portions (intake side of the cylinder) of the gasket..one of which is located where the old "water hole" was previously located.
Old Jun 18, 2008 | 06:20 PM
  #147
MADScientist's Avatar
MADScientist
Yes, as you can see the coolant flow is redirected to the exhaust ports to aid in cooling that portion of the heads... And that middle layer is a fire ring preloader that aids in sealing the combustion chambers under elevated cyl. psi.
Just another update, 4000 miles later and still no signs of head lift and no air in the cooling system. I have done several 3-4-5 gear pulls and now that it is hot outside my coolant temps still never get above 195 while the car is moving and 210 while sitting in traffic.
Old Jun 18, 2008 | 07:17 PM
  #148
leeboyNY's Avatar
leeboyNY
Kimchi Eater
210 is kind of high isn't it? I usually see 96C in traffic.. No oil cooler either..
Old Jun 18, 2008 | 07:38 PM
  #149
accordfreak
that's only 6 degrees off from yours
Old Jun 18, 2008 | 08:11 PM
  #150
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
not even close! my 08 stock 4 banger toyota truck runs about 193 with ac on.
Old Jun 20, 2008 | 09:57 AM
  #151
trvotypes's Avatar
trvotypes
car looks badass i love that bumper and with a blacked out fmic looks sick
Old Jul 12, 2008 | 08:32 AM
  #152
GreenGoblin's Avatar
GreenGoblin
Thumbs up
just read this whole thread great read thanks for all the info
Old Nov 3, 2008 | 10:45 PM
  #153
r0mey's Avatar
r0mey
bump car is still running fine? No signs of headlift? Im thinking HR headstuds and bolts are the way to go just asking to back up my thinking
Old Nov 4, 2008 | 05:19 AM
  #154
MADScientist
Originally Posted by r0mey
bump car is still running fine? No signs of headlift? Im thinking HR head studs and bolts are the way to go just asking to back up my thinking
The car has been running great as far as the internals of the engine are concerned... I had a upper radiator hose get torn open somehow, and no it was not head lift... and the Crawford plenum finally cracked (lie everyone else's) and had to have it re-welded.
But as far as head lift or cooling is concerned I have had absolutely zero issues, the motor has just under 9000 miles on it now and I leave the boost controller at 19psi all the time (626whp on DD). So this is being tested at my max power level on a daily basis, made it through the first season without a hitch, and I would expect nothing to develop at these power levels in regards to the head gaskets or head bolts.
Old Nov 4, 2008 | 05:48 AM
  #155
jumpin800agl's Avatar
jumpin800agl
8 to 11
Great to hear your car is doing well Joe.
Old Nov 4, 2008 | 05:51 AM
  #156
captj3's Avatar
captj3
This is good to hear. Nothing going wrong at a fraction of the price.
Old Nov 4, 2008 | 07:11 AM
  #157
eagletanggreen
Got Track!!!!!
Cant wait to get up there next week and give your car a well deserved raping. LOL
Old Nov 4, 2008 | 10:08 AM
  #158
XKR's Avatar
XKR
Good to hear Mad Scientist....You said the Plenum cracked. I take it because you said you had it welded you are not talking about the caps....where exactly did it crack??
Old Nov 4, 2008 | 10:31 AM
  #159
__jb's Avatar
__jb
Z + Rear Seat
He said it was a Crawford plenum... no caps... You might be thinking about the Cosworth.
I remember because I have a Crawford and I want a Cosworth... Like everyone else here, I suppose...
Old Nov 4, 2008 | 10:42 AM
  #160
XKR's Avatar
XKR
Thanks for that correction....I saw Luie post and i know that he had a Cosworth too.... I just assumed that Joe had the Cosworth also.
