Vortech V-20 series supercharger
Old Jun 2, 2008 | 03:07 PM
SDUrbn350Z's Avatar
SDUrbn350Z
Default Vortech V-20 series supercharger
i was looking into changing my V-2 super charger for a bigger one so i decided to go with the biggest one they have which is the V-20 series and i was wondering does anybody know if it is 50 state smog legal or if i could at least pass in California????????
Old Jun 2, 2008 | 03:27 PM
klimaxx805's Avatar
klimaxx805
Dude as much as I'd like to see a bigger blower (V7) in a Z someday it wouldn't work. It's way to big and you'd need to hack up your Z and build a custom bracket to make it work. The biggest you could probbably get away with would be a V7-YSI. I'd like to see GTM or someone build a Z/G with a V7 YSI. None of Vortechs race blowers V7 or bigger have a CARB EO #.
--Frank
Old Jun 2, 2008 | 03:32 PM
Floridaboy1605's Avatar
Floridaboy1605
Dude you are talking about putting a charger the size of like a honda wheel in your engine bay!! my T-Trim v2 is a close fit... you might MIGHT!! be able to fit a v1 in there..
Old Jun 2, 2008 | 04:11 PM
JonnyC's Avatar
JonnyC
I agree - the V2 is a very very tight fit.
Old Jun 2, 2008 | 06:11 PM
booger's Avatar
booger
The T-trim is the same size blower as the stock kit blower . It [ the T-trim ] is more than the 3.5 motor can handle as it is . Im putting 19 to 21 psi to mine , and it makes very littlle WHP per 1 PSI after 15 PSI . Going bigger would be a waist
Old Jun 2, 2008 | 06:21 PM
atomevolution's Avatar
atomevolution
Does a V1 fit and is there any advantage to using it over a V2? I don't really know what the difference is.
Are these blowers Counterclockwise or Clockwise rotation? Can either be used in these kits?
Old Jun 3, 2008 | 05:13 AM
QuadCam's Avatar
QuadCam
these are CCW rotation.
Old Jun 3, 2008 | 07:21 AM
05Z33's Avatar
05Z33
So are the internals of a T trim the only thing different form the stock blower?
Old Jun 3, 2008 | 07:32 AM
doug's Avatar
doug
from what i remember from the maxima days.. the V1 and V2 are almost the same.. but the V2 is much much quieter and has a better idler pulley.. the V1 sounds like angry crickets at idle
Old Jun 3, 2008 | 07:49 AM
klimaxx805's Avatar
klimaxx805
The inlet on the volute is a little bigger on the T. The S-Trim has a 3.50" inlet and the T-Trim has a 3.75" inlet.
I agree with booger. I believe the 3.5 is at max with a T. You'd need a stroker motor to take advantage of anything bigger.
V1 VS V2...a V1 has straight or spur cut gears (makes the blower louder at idle) and a V2 has helical cut gears (makes the blower quieter at idle).
--Frank
Old Jun 3, 2008 | 11:54 AM
QuadCam's Avatar
QuadCam
the V1 blowers use straight cut gears (which I prefer. stronger, but alot louder). the V2s use helical cut gears (much quieter) also the internal step up ratio is slightly higher on the V2 compared to the V1....only slightly though.
Old Jun 3, 2008 | 01:00 PM
asianflip06's Avatar
asianflip06
Yeah I am running the V1 Setup....Louder than **** lol.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Twenty4
Jan 17, 2016 01:20 PM
