Hot starts, injectors, ecu, what?
Old Jun 9, 2008 | 08:11 AM
  #41
al_v's Avatar
al_v
I have the problem ( utec, rc 550cc injectors and 3.5 bar FPR ), I´m really tired of this issue , and the solution is get a EMS like Haltech , F-con , etc , or reflash the ecu for bigger injectors , or wait a little for the new UP-REV software......
The problem here is the cranking injectors time......
Old Jun 9, 2008 | 09:19 AM
  #42
Hexxum001's Avatar
Hexxum001
Originally Posted by KPierson
How big are the injectors?
Sorry. I am running 550cc DW injectors with the HKS FCon iS. No hot start issues at all with that combo.
Old Jun 9, 2008 | 03:36 PM
  #43
SpoilsofWar's Avatar
SpoilsofWar
Originally Posted by craigo'sznprgrs
Who tuned your car?
Bobby at Performance Race Engineering in Portland, OR
http://www.preracing.com/
Old Jun 9, 2008 | 05:57 PM
  #44
rcdash's Avatar
rcdash
Haltech, HKS 1000 cc injectors, hot starts were never a problem. Starts just like stock - immediately. Cold starts used to take 2 cranks (no gas required), with a little fine tuning, it only takes 1 but the first crank is not quite perfect yet (at about 1-2 seconds it starts to die a little, but then picks back up).
Haven't had a chance to play with it too much but I know there's a cold start enrichment that lets you adjust fuel at specified time intervals after cranking begins (offset % from base fuel table)... It's a little bit of a stab in the dark since you can't get an A/F reading until the O2 sensor warms up (15 seconds for me).
Old Jun 9, 2008 | 06:04 PM
  #45
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Raj, let me know about this stuff The HKS injectors are nice and don't give any problems when dialed in.
A little more prime pulse and cranking injector will make it start immediately. Then add a little fuel from 2-5 seconds after engine start in the 'post-start' fuel table.
Old Jun 9, 2008 | 06:05 PM
  #46
Jay'Z's Avatar
Jay'Z
How would a reflash fix this?? If this is true id send my ecu to uprev again for this!!
Old Jun 10, 2008 | 07:08 AM
  #47
al_v's Avatar
al_v
You need to reflash the ECU for bigger injectors , this would reduce the cranking injector times , and this would solve all that hot starts issues.
Old Jun 10, 2008 | 10:04 AM
  #48
rcdash's Avatar
rcdash
It's near perfect - not an issue at all. Thanks though - I don't want to waste your time with trivial stuff when you've got really cool stuff coming out that better deserves your attention.
Old Jun 10, 2008 | 11:47 AM
  #49
coachk's Avatar
coachk
Originally Posted by captj3
That is very strange. I've had my utec for a year now with my aps tt and never had a problem starting. Are you still using the aps fuel set up?
+1 never an issue with my Utec and APS injectors on warm/hot starts. Still have the UTEC but now have DW 600 injectors and every now and then I have an issue with warm starts, but not a big deal.
Old Jun 10, 2008 | 12:30 PM
  #50
05Z33's Avatar
05Z33
So if we reflash the ECU for larger injectors, do we need to retune the utec as well or leave it as is?
Old Jun 10, 2008 | 12:39 PM
  #51
al_v's Avatar
al_v
You will need to change the values in the 0% column ( if you make a reflash for your 550cc injectors , the value would be 0 in that column ), the rest of the map doesn´t need any change , I assume that you are using the speed density mode.........
Old Jun 10, 2008 | 02:04 PM
  #52
05Z33's Avatar
05Z33
Jeremy at PF is my tuner, so I'll have to have him do it for me. I wish I knew how to do my own tunning. I'll just wait till I upgrade my pulley before I have the reflash and retune.
Old Jun 10, 2008 | 02:27 PM
  #53
failsafe306's Avatar
failsafe306
Originally Posted by leeboyNY
I have HKS low impedance 1000cc, f con v pro, GTM ECU reflash and no problem with hot starts.
I had Precision 1000cc low imp injectors, V-Pro, NO reflash, and it still started up every single time, no problem.
I miss my car
Old Jun 10, 2008 | 04:52 PM
  #54
JonnyC's Avatar
JonnyC
If you end up going through with that you'll have to let me know how it goes. And if all a tuner will have to do is change the 0% column you would be able to do that yourself real easy. I assume you would just have to pull the ecu and send it out to be flashed. I would love to do that but not sure if I'm willing to pay the $400 or whatever it would be.
Old Jun 10, 2008 | 04:56 PM
  #55
Jay'Z's Avatar
Jay'Z
Im willing to pay 300 to 400 just waitin on a response from uprev..
Old Jul 2, 2008 | 12:22 PM
  #56
Jay'Z's Avatar
Jay'Z
Ok, got the flash from uprev.. Hot starts still require mashing the throttle...
I guess ill try the 0 in 0% column of utec..
Old Jul 4, 2008 | 04:48 AM
  #57
Madelinot's Avatar
Madelinot
I also have a UTEC with my APS TT kit and it starts really quick, hot or cold. In fact, it starts the same as when I had the Unichip. I'm still running the APS supplied injectors for now.
Old Jul 4, 2008 | 04:54 AM
  #58
Jay'Z's Avatar
Jay'Z
Do you have huge 750cc like me?? What is your fuel map looking like at the 0 column?
Old Jul 4, 2008 | 07:37 AM
  #59
westpak's Avatar
westpak
SFZCC
He says he has stock APS injectors so he wont have startup issues
You need to step up to a real EMS I have 1000cc injectors and cold and hot startups with the Fcon are fine
Old Jul 4, 2008 | 07:58 AM
  #60
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
You should get a fcon and all your problems will be resolved!
