Turbo Timer Install?
Old Jun 9, 2008 | 07:12 PM
SC 350Z's Avatar
SC 350Z
Default Turbo Timer Install?
I have the turbonetics kit wit hthe water lines i just recently bought an apexi turbo timer it has instructions on how to hard wire it and i was just wondering if anyone coul shed some light on how to do t his im kinda iffy on doing this im good with electrical but you know what i mean.
Old Jun 9, 2008 | 07:18 PM
wannabuy350z's Avatar
wannabuy350z
^search, many threads. plus, if its only wanter cooled. its not that big of a deal like oil.
or maybe im wrong
Old Jun 9, 2008 | 07:20 PM
merlin3's Avatar
merlin3
you're right if it's water cooled it's not as big of a deal. Even if it wasn't, if you don't drive the car hard for the last couple minutes you'll be fine. But it is a fairly easy install, should be write up on here.
Old Jun 10, 2008 | 11:17 AM
SC 350Z's Avatar
SC 350Z
so since its a water cooled turbo shouldnt be to much of a problem not having a turbo timer? i do let it idle for a few seconds when i stop. just as long as im not horsing on it then shutting it off right away?
Old Jun 10, 2008 | 11:32 AM
wannabuy350z
just before you reach your final destination, just cruse your way there. and you can turn it off right away or let it set for 20 sec
Old Jun 10, 2008 | 11:46 AM
SlideFox's Avatar
SlideFox
Oil cooled turbo's are more prone to failing if not properly cooled. The oil has a tendancy to "bake" the seals in the turbo. With a water cooled turbo, your system is cooling the liquid, and it retains less heat.
Old Jun 10, 2008 | 01:05 PM
SC 350Z's Avatar
SC 350Z
^ thats what i was thinking, so no turbo timer?
Old Jun 10, 2008 | 01:08 PM
Nexx's Avatar
Nexx
another neat way to get a turbo timer and add some security to your car:
http://www.bestbuy.com/site/olspage....=1083710247578
viper alarm system with 2 way pager and built in turbo timer.
the price includes install.
Old Jun 10, 2008 | 01:12 PM
SC 350Z's Avatar
SC 350Z
^ thanks that dont look to bad of a deal kinda iffy on some of the revieews on it though
Old Jun 10, 2008 | 01:15 PM
Nexx's Avatar
Nexx
no product is perfect but the more you read, the better the reviews get. majority of the customers seemed very satisfied. i'll getting one installed once my car is back here shortly.
Old Jun 10, 2008 | 01:29 PM
SC 350Z's Avatar
SC 350Z
yea there was only one or two i saw that wasnt satisfied with it
Old Jun 13, 2008 | 11:45 AM
MIAPLAYA's Avatar
MIAPLAYA
I did a whole write up on installing a turbo timer. Go to this thread:
https://my350z.com/forum/showthread....ht=turbo+timer
My turbo timer was a Blitz FATT DCIII but the wire colors are exactly the same for the Apexi. Trust me on this as I have installed two Apexi turbo timers on buddies cars before.
Old Jun 13, 2008 | 01:25 PM
SC 350Z's Avatar
SC 350Z
^thanks man i might try to do this
Old Jun 18, 2008 | 11:47 AM
MIAPLAYA's Avatar
MIAPLAYA
Its incredibly easy to do. If you aren't comfortable soldering you could always use t-taps.
Old Jun 18, 2008 | 12:20 PM
jeffie7's Avatar
jeffie7
Bestbuy option isn't bad but do keep in mind, chances are they wont install it on a 6 speed. doesn't mean you can't buy it and install it yourself.
Either way, I don't think it's needed, I thought about doing a turbo timer but have found the same answer over and over, if its water cooled its good to go.
Old Jun 18, 2008 | 12:51 PM
UMW350Z's Avatar
UMW350Z
I am easy on it for the last couple miles then idle for about 20 seconds. The turbo seems to wind down completely within 15 seconds of shutoff.
Old Jun 18, 2008 | 04:27 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Yeah I found out about the viper alarm w/ option of turbo timer 1 week after I had my timer installed oh well
Old Jun 19, 2008 | 07:28 AM
MIAPLAYA's Avatar
MIAPLAYA
Even with a water cooled bearing installing a turbo timer won't hurt. Yes in theory with a water cooled bearing housing the bearing temps stay low enough to prevent any coking when the motor is shut off but even still it doesn't hurt to let the motor cool down for a minute prior to shutdown. Turbo timers are relatively cheap at $100 and take under an hour to install. You could do the alarm thing but again more money when you already have a factory alarm that works just fine. To each their own. its personal preference honestly.
Old Jun 19, 2008 | 07:34 AM
Barzten1's Avatar
Barzten1
subscribe
Old Jun 20, 2008 | 03:11 AM
rxkevin's Avatar
rxkevin
Turbo timer install was pretty easy. I took a look at the write up Miaplayer posted when I did my install and it helped a lot.
Quick summary of his post for which wires you need to tap into are :
12v (+) white/blue stripe
Ignition (+) black/red stripe
Accessory (+) white/black stripe
And any good ground
