Proper way to Clean an Intercooler
Old Jun 11, 2008 | 03:02 PM
wannabuy350z's Avatar
wannabuy350z
Default Proper way to Clean an Intercooler
Hello,
I have search the forums, and didnt find any info on this.
since there is always some oil resedue on our piping, i am sure that someof it gets stuck in the intercooler, causing less efficient flow.
whats the perfect way of cleaning an intercooler, I would like to do this soon.
I have heard of people letting the FMIC soak in soap and warm water, but I'd rather see what you guys think!
Thanks...
Old Jun 11, 2008 | 03:21 PM
thawk408's Avatar
thawk408
Soak it. Then let it dry.
Old Jun 11, 2008 | 03:24 PM
wannabuy350z
should I use any pressure from one side to get the dirt out at all?
Old Jun 11, 2008 | 03:33 PM
thawk408's Avatar
thawk408
I would spray some mild degreaser in it, then spray inside with a hose pointing down.
Old Jun 11, 2008 | 03:36 PM
wannabuy350z
i'll def do that this week. hopefully that will be not much dirt/build up in there!
Old Jun 11, 2008 | 03:37 PM
thawk408's Avatar
thawk408
I doubt there will be much if any, unless something is wrong.
Old Jun 11, 2008 | 04:00 PM
tig488's Avatar
tig488
fill it full of water, then crank the car and run it for 10 minutes.
Old Jun 11, 2008 | 04:01 PM
tig488's Avatar
tig488
^only kidding.
Old Jun 11, 2008 | 04:33 PM
wannabuy350z
^LOL, I hope no one fell for that...
Old Jun 11, 2008 | 05:02 PM
bboypuertoroc's Avatar
bboypuertoroc
Here's how I clean mine...
Remove from car (obviously).
Clean up the outside (whatever's easiest for you).
Get a plastic bag and a rubber band. Place bag over one opening and secure with rubber band.
Get some gas.
Pour some in the intercooler.
Tie up other end of intercooler same as the first.
Swish the gas around inside the core for a good 5-10 minutes.
Undo one side and drain gas (it will come out almost black).
Repeat until gas comes out same color it went in.
Remove bags/bands, drain gas completely, and dispose of.
Clean outside of intercooler again.
Let dry completely.
Reinstall.
Perform boost leak test.
Drive.
Old Jun 11, 2008 | 05:10 PM
athenG's Avatar
athenG
I created a thread about this so here it is.. https://my350z.com/forum/forced-induction/345612-how-to-clean-fmic.html
Old Jun 11, 2008 | 05:32 PM
minus500's Avatar
minus500
An acidic solution will work well. Makes stainless and aluminum look almost new again.
Old Jun 11, 2008 | 06:09 PM
wannabuy350z
^which acid sulotion do you recommend
Old Jun 11, 2008 | 07:21 PM
minus500's Avatar
minus500
Oxalic, Phosphoric, or Hydrochloric. These are powerful oxidizers and should be diluted but the results are good.
Old Jun 11, 2008 | 10:13 PM
wannabuy350z
^wtf
Old Jun 12, 2008 | 12:17 AM
bboypuertoroc
Originally Posted by dave079
Wow that's random Dave.
Tony (sees that's how Phreak cleans intercoolers)
Old Jun 12, 2008 | 05:30 AM
05Z33's Avatar
05Z33
Get some gas.
Let dry completely.
Reinstall.
Drive.
Wow that's an expesive cleaning considering the price of gas now a days. I would just use simple green degreaser.
Old Jun 12, 2008 | 05:32 AM
NickRaine78's Avatar
NickRaine78
Haha I figured people would get the joke of phreak trying to clean the intercooler with the hose. Found the pic in the photochop thread.
damn you beat me to it.....that pic was the first thing I thought of when i saw dis fread title
