Proper way to Clean an Intercooler
Old Jun 12, 2008 | 08:06 AM
JETPILOT's Avatar
JETPILOT
Brake cleaner. Just spray it inside. Don't use simple green it corrodes aluminum.
Old Jun 12, 2008 | 08:10 AM
gothchick's Avatar
gothchick
Just stating the obvious, but a catch-can will help catch oil before it gets into the IC.
Old Jun 12, 2008 | 09:28 AM
bboypuertoroc's Avatar
bboypuertoroc
It still gets a little nahsty in there. But you're right, a catch can will keep it MUCH cleaner.
Originally Posted by 05Z33
Wow that's an expesive cleaning considering the price of gas now a days. I would just use simple green degreaser.
You must be broke to not be able to afford a gallon or two of gas.
Simple Green? Wrong answer. Better to clean with something that not only works fantastic for the job, but also gets injected into the engine already as it is so you don't have to worry about any possible issues.
Old Jun 12, 2008 | 09:37 AM
05Z33's Avatar
05Z33
I was not aware of that. Thanks for the info.
Old Jun 12, 2008 | 09:39 AM
05Z33's Avatar
05Z33
I was trying to be funny. I failed.
Old Jun 25, 2008 | 07:21 AM
Barzten1's Avatar
Barzten1
I have a catch can and noticed some oil in the piping right before the intercooler. Motor and kit has less than 3k miles on it. Is this normal?
Old Jun 25, 2008 | 07:26 AM
rcdash's Avatar
rcdash
Turbo oil seals leak oil, some more than others. An oily residue build up in the IC may be more common than you think. Open a coupler and stick a finger in a pipe... With the G35 JWT TT IC, you can clean the IC without removing them since they both tilt down and have a removable center piece - quite convenient. You can also hook the piping up, minus the center T and dry out the ICs by idling the car.
Old Jun 25, 2008 | 07:37 AM
Barzten1's Avatar
Barzten1
Thanks. Ill have to see how convienient my intercooler would be to take off and clean. Im running Mobil 1 10w-30 and a quart of Lucas Synthetic oil stabilizer. Should I switch to a different weight?
Old Jun 25, 2008 | 08:17 AM
rcdash's Avatar
rcdash
Unless you see freezing temps, I'd run 15W-50. Turbos get that oil hot! Sharif has me run 10W-40 in the winter and 15W-50 in the summer here in NC.
Stevo Z
Oct 3, 2015 09:14 PM
_bit
Oct 2, 2015 07:49 AM
Depravity
Oct 1, 2015 04:49 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
