aeromotive FPR fuel leak.
Old Jun 15, 2008 | 08:12 AM
jeffie7's Avatar
jeffie7
Default aeromotive FPR fuel leak.
The leak is coming from where the red top piece meets the silver bottom piece.
I've removed the top half, checked the diaphragm and found it to look clean with no rips, reinstalled the top half, still no luck, fuel just slightly runs down the side of the FPR, with a drop light on it you can see it slowly coming out. =(
Any ideas on getting it to stop leaking?
Old Jun 15, 2008 | 08:43 AM
QuicksilverZ33's Avatar
QuicksilverZ33
Should there be a gasket there?
Old Jun 15, 2008 | 09:11 AM
jeffie7's Avatar
jeffie7
The rubber diaphragm works as a gasket.
Old Jun 15, 2008 | 09:18 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Contact aeromotive for a replacement gasket and torque specs. I have used many of these and never had that problem.
Old Jun 15, 2008 | 09:25 AM
SlideFox's Avatar
SlideFox
+1 on what Hal said Jeffie. I have seen many of these used and never had a leak. Could be the wrong thickness gasket or the wrong torque specs.
Old Jun 15, 2008 | 10:42 AM
jeffie7's Avatar
jeffie7
anyone know the torque specs? I assume that it's torqued from the factory, and in my case it's leaked since day 1.
I'll call them or see if Dave can call them since he might have more leverage.
What's weird is the surface seems fine, it looks machined with no signs of damage, the rubber diaphragm also seems fine.
weird that it's leaking, it is a pretty slow leak but enough to drop fuel pressure from 45 or so down to 25 in a few minutes.
Old Jun 15, 2008 | 12:05 PM
Old School's Avatar
Old School
Shift_Boost
weird...mine works fine. good luck with that fuzzy. did that one come with your kit or did you buy it separate?
Old Jun 15, 2008 | 12:51 PM
jeffie7's Avatar
jeffie7
I bought it from Dave @ FT, I have no doubt he'll fix things for me, I'm just trying to do some leg work myself, I hate having someone else do something I know I can do, however in this case I think it might just be a bad FPR. =(
Old Jun 16, 2008 | 06:30 PM
jeffie7's Avatar
jeffie7
Called Aeromotive today since FT is close, talked to one of the techs there, he told me that it's leaking out of the front hole where the gauge goes, I told him that I wrapped it around 3 times with tape and tightened it up rather tight and would be surprised if it were still leaking, also that it looked like the fuel was coming from where the top part and bottom part meet, he told me that he gets calls for this same problem time and time again and also has people send them in with the same problem, almost always, its from the gauge hole in the front.
I took it apart again, checked over the surface again, every thing looked perfect, cleaned out all of the fuel, then covered the little gauge hole plug with Hondabond, loaded it up around the outside of the hole and then put the top of the FPR back on then made sure everything was put back together with out pinching the rubber gasket, I also torqued down on the little plug rather tight, sounds like it takes a good bit of force to get it seated right.
I'm letting the hondabond dry for 48 hours so the fuel wont wash it away, we'll find out on Wednesday if it holds.
*keeps figures crossed*
Old Jun 16, 2008 | 08:04 PM
fstrnldr's Avatar
fstrnldr
i love hondabond more than probably anyone, but have never gotten it to work well to seal a NPT thread. You are giving it a longer dry time than i think i ever did though .... if it doesn't work use a pipe thread PASTE, not tape, that should work much better than the tape.
Old Jun 16, 2008 | 08:07 PM
blueper4mancez's Avatar
blueper4mancez
i had the same problem , i just seal mine with clear silicone , kinda ghetto but it does it job .
Old Jun 16, 2008 | 09:24 PM
jeffie7's Avatar
jeffie7
That's what I wanted to use, but didn't have any around, was told by a few people liquid gasket should be fine as long as it drys before fuel hits it, if not I'll get some thread paste.
We'll see.
I believe Hondabond is silicone based, only down side is the stuff is 18.95 a tube.
Old Jun 16, 2008 | 09:46 PM
Weqster's Avatar
Weqster
i usually use loctite/thread locker on all threaded connections. And then try and give them 6-12hrs to dry. Ive used thread tape before and that stuff just isnt reliable enough... Never had an issue using the above method.
Old Jun 17, 2008 | 04:17 PM
jeffie7's Avatar
jeffie7
24 hours later it still feels a bit soft, hopefully it will hold tight tomorrow. Yes it's over kill, but it should allow me to see if the fuel is in deed coming from somewhere else. =)
Old Jun 17, 2008 | 07:30 PM
UMW350Z's Avatar
UMW350Z
It's OBVIOUS that this FPR is telling you that you need more boost or else it'll just spit out the fuel you'd use on 12 PSI anyways. I bet this sucker would be around 500 whpr at 12, maybe even 11 psi with a good exhaust
Old Jun 17, 2008 | 08:41 PM
jeffie7's Avatar
jeffie7
Maybe, however, the kit is not the weak link.
Old Jun 17, 2008 | 08:51 PM
SlideFox's Avatar
SlideFox
Your right... the stock connecting rods are!
Old Jun 19, 2008 | 04:16 PM
jeffie7's Avatar
jeffie7
Seems to be fixed, hopefully it holds up.
Old Jun 19, 2008 | 07:48 PM
phunk's Avatar
phunk
CJ Motorsports
i dont think hondabond holds up in fuel?
Old Jun 19, 2008 | 08:23 PM
jeffie7's Avatar
jeffie7
Well, it's just in the threads and on the outside. guessing for the most part it works as loctite but with maybe a small enough of sealing power.
Either way, leak stopped, at least for now.
