Help with coolant.
Old Jun 12, 2009 | 06:30 AM
coachk's Avatar
coachk
So what method are you doing. I wish someone would make a bleeder valve for the APS TT system....hint hint
Old Jun 12, 2009 | 06:31 AM
SIR_pierre's Avatar
SIR_pierre
so how do you do it in 20 mins now?
and the "extra container/tank" that is connected to the radiator. how mutch water should i have in that?
Old Jun 12, 2009 | 06:32 AM
coachk's Avatar
coachk
What type of turbo system do you have?
Old Jun 12, 2009 | 06:38 AM
350 Rookie's Avatar
350 Rookie
Its actually very easy now. I jack the front up. I open the bleeder screw on the heater hose. pour water in the reservoir and keep pouring water in the radiator until i see come out the bleeder hole on the hose. Once i see that, i screw it in and fill up the radiator and leave the cap off. I start the car, blast the heat and hold the rev to 2k rpm constant. Fill the radiator as it goes down. once it stops going down, I take it for a drive, its not fully bled yet but i go for a drive anyways and the remaining air clears its self out. Make sure you have plenty of water in the reservoir because as your driving, its gonna take water from it. HOWEVER when you are driving, you will see the water temps raise up but it never hits H. its 3/4 of the way up there but eventually it dropps and drops to normal temps and then you can feel the heat in your face.
Old Jun 12, 2009 | 06:57 AM
SIR_pierre's Avatar
SIR_pierre
moi? GReddy , and a koyorad 53mm if that mather...
but i really cant find the bleeder screw...i have everything covered in heat shield...stuff..
resevoir is the extra tank right? fill it up?
what i dont understand about my tank is that the hose in on the lock..that sits on the top..and there is a breathing hole on the lock aswell...it wont suck **** from that tank..
could the bleeder be behind this maybe?
Old Jun 12, 2009 | 07:07 AM
350 Rookie's Avatar
350 Rookie
LOL. why did you put your coolant reservoir in your bettery spot?
Old Jun 12, 2009 | 07:09 AM
SIR_pierre's Avatar
SIR_pierre
i ran out of space
Old Jun 12, 2009 | 07:20 AM
350 Rookie's Avatar
350 Rookie
lol. do you have a pic of your engine bay with everything in?
Old Jun 12, 2009 | 07:28 AM
SIR_pierre's Avatar
SIR_pierre
hmm.not a good close up.. fell free to browse
http://s163.photobucket.com/albums/t309/SIR_Pierre/
Old Jun 12, 2009 | 07:37 AM
350 Rookie's Avatar
350 Rookie
I put my tank here.
Old Jun 12, 2009 | 07:49 AM
SIR_pierre's Avatar
SIR_pierre
allright.. mine wouldnt fit there between the engine and radiator and if i mounted it just above the radiator as with the oil catch tank then the hood wouldnt close ( with it didnt to anyway later becuse of the strut bar)
and since i moved my battery to the trunk so,,,why not use the space =)
so i have the containers for the raidiator and washfluid there
Old Jun 12, 2009 | 10:54 AM
bbs350z's Avatar
bbs350z
i dont get whats so difficult about this?
Old Jun 12, 2009 | 02:28 PM
superchargedg's Avatar
superchargedg
Damn Noobs
It will be right next to what looks like your fuel pressure regulator in the heater hose.
Old Jun 12, 2009 | 08:13 PM
Zivman's Avatar
Zivman
You should have done like I did - splice the line and keep the stock bleader. If you still have your stock T with bleeder, just splice it back in line
Old Jun 12, 2009 | 08:18 PM
doug's Avatar
doug
a guy with a 07 nismo TT z wants motor work done.
details on mods?
Old Jun 13, 2009 | 01:04 AM
coachk's Avatar
coachk
When I did the TT install I threw it away. I'll see if I can pick one up from nissan.
Old Jun 13, 2009 | 03:23 AM
SIR_pierre's Avatar
SIR_pierre
maybe we did that to... why do you change that when you install a TT kit? are there a replacement hose for that in a TT kit?
Old Jun 13, 2009 | 06:07 AM
  #38
350 Rookie's Avatar
350 Rookie
Originally Posted by doug
details on mods?
Custom Turbokit made by AAM, Twin gt28's i beleive on stock HR motor pushing 507whp. I beleive hes on this forum. I dont know his name
Old Jun 13, 2009 | 04:50 PM
  #39
coachk's Avatar
coachk
Yes the APS TT kit comes with a replacement
Old Jun 13, 2009 | 04:52 PM
  #40
SIR_pierre's Avatar
SIR_pierre
could it be so on the GReddy TT kit to?
