Vortech issue please help
Old Jun 20, 2008 | 11:38 AM
turtle1678's Avatar
turtle1678
Default Vortech issue please help
Ok guys I have a question? I just had my car in for service about 2 weeks ago for an oil leak so nissan replaced all the gaskets 2 days after getting the car the throttle body goes out and they replace it. its been about 6 days since I got it back I am driving today an all of a sudden my car starts dying out when I give it gas I look under my hood and I have oil from my vortech the filter was soaked, what could have caused this?? it was working great before nissan took it apart, what are reasons that this could have happened? and I have only bee getting like 5 psi with the stock pulley since they took it apart? All the bearings and seals were replaced like 2 months ago and have less than 200 miles on them.
2003 nonrev
Old Jun 20, 2008 | 12:19 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
nissan does warranty work on your car even with the vortech?
Old Jun 20, 2008 | 01:12 PM
stormcrow's Avatar
stormcrow
could be a pinched oil feed line. but, question. why would you allow a nissan dealership to EVER work on your boosted car?
Old Jun 20, 2008 | 02:34 PM
frankie945's Avatar
frankie945
Vortech has belt slipping problems the stealership probley didn't get your belt tight enough thats why you are only seeing 5 psi. I have no Idea why your filter was soaked.
Old Jun 20, 2008 | 02:49 PM
turtle1678's Avatar
turtle1678
The reason they had the car was that they did prior work that was under warranty and I think when they got it all together they pinched the oil return line if that is the case do I just have to change the seal?
Old Jun 21, 2008 | 03:07 PM
Midnight Ryderz's Avatar
Midnight Ryderz
if you have oil in the filter get it back to vortech the inside seals are bad hope this helps i had the same problem good luck
Old Jun 21, 2008 | 03:52 PM
05Z33's Avatar
05Z33
I think you maybe right. You should get your car up on jack stands and do a thurough inspection. I would probably remove the blower and have that inspected as well. Good luck with all this.
Old Jun 22, 2008 | 06:56 AM
turtle1678's Avatar
turtle1678
I figured it was the blower seals, but heres another question, if it is the blower and I send it to vortech can I remove the oil sending unit, plug my oil pan spacer take out my intercooler pipe and add a filter and plug in the stock ecu and drive it until I get it back from them
Old Jun 22, 2008 | 02:35 PM
350Z400rwhp's Avatar
350Z400rwhp
yup
Old Jun 23, 2008 | 04:19 AM
jpc350z's Avatar
jpc350z
Oil on the inlet filter is probably why your only seeing 5 psi..Not enough air getting in. It's not likely the seals inside the blower is causing the filter to get clogged with oil. Also the oil feed line and return are in back of the blower and not likely the source of the oil..Did the dealer remove the vortech mounting bracket. If so make sure they replaced the shims on the backside of the bracket that mount to the cover of timing chain.The reason I say this is I had a similar problem and found out the shim was not installed...Oil will leak out at this location and spray around.
Old Jun 23, 2008 | 07:44 AM
turtle1678's Avatar
turtle1678
HEREIS THE Verdict guys, nissan calls me and goes can you come in there is a few things the mechanic wants to show you, I said no I have a sprained ankle and no car how am I gonna get there whats wrong with it. They tell me that there is a kink in the oil return line. they were the last ones to take it out an reinstall the charger so I think they are #^%%ing themselves b/c I told them that I want it fixed now. They did a gasket overhaul and charged me $350 more than it would usually cost b/c they had to take it out. Has anyone else had this happen before????
Old Jun 23, 2008 | 08:05 AM
frankie945's Avatar
frankie945
you should have never took it to the dealer there techs don't know sh*t about SC's or turbo's.
Old Jun 23, 2008 | 05:13 PM
turtle1678's Avatar
turtle1678
I didnt want to take it to them there just isnt anywhere around here that will work on my car. I usually do the work but I dont have the time to do it now, you would think for $110 an hour, and considering all they had to do was remove 5 10m bolts and one 15m they could handle it. I dont see how you can be a mechanic who is going to work on a GTR and cant handle a vortech on a 350 just doesnt make sense. one feed and one return. I dont know though. I filed a complaint with nissan and I will hear something tomorrow
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
