Looking for help.. NO spark on right (passenger) side
Old Jun 30, 2008 | 12:10 PM
Russ@Z1's Avatar
Russ@Z1
Default Looking for help.. NO spark on right (passenger) side
Summary of issue. (not my Z)
Greddy kit installed, Utec installed, no tune
Z has been running fine, but rich, for approx 1400 miles with no issues
No abuse, just normal driving
A few days ago, arriving at destination, Z dies
Check spark, only left (driver's) side fires
Check plugs, change plugs due to them running so rich
Unplug Utec, same issue
Does anyone have any insight as to what may be causing right (passenger) side not to fire? No spark at all on right side, but left side fires.
Old Jun 30, 2008 | 12:34 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
are you sure its the whole passenger side, there is a subharness that controls the front two coils on passenger side. make sure after you get it situated, you bring me the car to tune
Old Jun 30, 2008 | 12:37 PM
Russ@Z1's Avatar
Russ@Z1
I'll double check that, but I believe it's all three.
Old Jun 30, 2008 | 12:40 PM
Russ@Z1's Avatar
Russ@Z1
Oookay. With confirmation, only the front two were checked. I've sent him back to check the third and confirm that the subharness is connected properly.
Just in case, is there somewhere where the subharness may be disconnected or any other issue that may result in it preventing spark in the front two?
Old Jun 30, 2008 | 02:22 PM
TurboSam's Avatar
TurboSam
ok, no spark on plugs 1, 3, and 5. checked thru steps 10 on IGN diag in the service manual. storm picked up outside couldnt continue to test voltages etc. so far everything has checked out OK, so im hoping im narrowing it down. with the luck ive had lately, im thinking its entirely possible, however unlikey, that i had a voltage spike that fried all 3 coils on that side. but thats a total shot in the dark at this point
Old Jun 30, 2008 | 02:26 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yes, you can take that little sub harness off. It's right on top of the valve cover. Disconnect and inspect for cuts/frays/etc. If it looks good then it might have just been loose.
Old Jun 30, 2008 | 02:28 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You can swap your coils from side to side and then see if you get the same problem. If you do it's your coils, if not then it's the harness
Old Jun 30, 2008 | 02:34 PM
TurboSam's Avatar
TurboSam
havent made it that far yet. wanted to go step by step for what the manual called for.
Old Jul 1, 2008 | 11:58 AM
TurboSam's Avatar
TurboSam
so far, still no luck finding the issue. i have done every all the test shown by the service manual. i have continuity from the ECU to the coils so far as i can tell, (pin 1 on the coils to pins 60, 61, 62, 79, 80, 81..... one pin per coil) i have not been able to check the coils, i do not have the proper tool.
bump for advice
Old Jul 1, 2008 | 12:18 PM
Russ@Z1's Avatar
Russ@Z1
have you swapped coilpacks from the left side?
Old Jul 1, 2008 | 12:48 PM
TurboSam's Avatar
TurboSam
i ended up testing the coilpacks with a multimeter, they tested ok. its gotta be a bad connection somewhere, i just cant find it
Old Jul 1, 2008 | 02:04 PM
TurboSam's Avatar
TurboSam
is it possible my ECM crapped out??? i seem to be getting a good reading on all the test functions as described in the Service Manual. I might go back and double check some things tomorrow, but im at a loss at this point.
Old Jul 1, 2008 | 03:01 PM
Russ@Z1's Avatar
Russ@Z1
possible....
Old Jul 1, 2008 | 04:37 PM
TurboSam's Avatar
TurboSam
does anyone know of a way to test the ECM? i cant find such a procedure in the service manual
Old Jul 1, 2008 | 06:33 PM
rcdash's Avatar
rcdash
swap left to right. if it still is crapped out on the left, then you know it's not the coilpack for sure. you could ask a friend to swap in their ECU. I think you'll need their key to start the car. I would not plug in the UTEC or the UTEC harness in any way as that may have caused the issue with your ECU, if it is indeed the ECU. Then you may end up with 2 burned out ECUs.
Old Jul 1, 2008 | 07:02 PM
Russ@Z1's Avatar
Russ@Z1
Well, a few of my friends work at the local dealership that has a ford lot and nissan lot. One of the techs from the nissan side stated that a faulty knock sensor has been known to cause one bank to completely shut down.
I texted that to you earlier, but I'm not sure if you've had time to check that sensor yet.
Old Jul 1, 2008 | 07:54 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
have you scanned for codes? Scan for codes before disconnected the battery....
Old Jul 1, 2008 | 08:51 PM
westpak's Avatar
westpak
SFZCC
I doubt it, my sensor wiring melted through and all it did was retard timing to 10 degrees at WOT
Old Jul 1, 2008 | 08:52 PM
westpak's Avatar
westpak
SFZCC
^+1 there may be a stored code that has not set off the light yet
Old Jul 2, 2008 | 05:48 AM
TurboSam's Avatar
TurboSam
whatever happened to it didnt have time to set a CEL. that was the first thing i checked. i drove it down the road no problems, got to my parents house, pulled in the driveway, an it started to idle rough, then shut down. i immediately assumed it was the plugs since it has been running really rich since the turbo install. i pulled the plugs out and they looked pretty rough, so i swapped them for new, tryed to start, and it would run about halfway. went and pulled plugs on bank 1 (just b/c they are easiest to get to) and none of the new plugs had fired at all......
come to think of it, i never actually checked to make sure there was no spark when i saw that. i just assumed they werent sparking since there was no evidence of combustion on the plug. i guess technically if its not getting any fuel, i could have gotten the same results....... f*ck, now i gott go start over.
