Reuse oil?
Old Jul 6, 2008 | 03:19 PM
Blwn_By_Twins's Avatar
Blwn_By_Twins
Default Reuse oil?
I changed my oil the other day and noticed oil on the garage flood this morning. Got under the car and can see a drop of oil from the drain bolt. Checked it and it's tight. I'm guessing the crush washer is shot. I'm going to get a new one, but the oil only has about a hundred miles on it. Can it be reused?
Old Jul 6, 2008 | 03:21 PM
350 Rookie's Avatar
350 Rookie
you can reuse it but make sure you dump it in a brand new container so you dont contaminate it. and besides, whats the piont. just buy new oil.
Old Jul 6, 2008 | 03:27 PM
XKR's Avatar
XKR
Its not how old the oil is....its what you may pour into the motor by doing that. Not worth taking a chance on saving a $$$ on oil .
Old Jul 6, 2008 | 03:28 PM
jgregory124's Avatar
jgregory124
yeah I would buy new oil ........you could keep the other stuff around for lube..ie seals, gaskets etc....
Old Jul 6, 2008 | 03:58 PM
350Z400rwhp's Avatar
350Z400rwhp
I would make sure you drain it into a brand new or very very clean oil pan and make sure nothing falls in your oil. You could always use a strainer or like a wire mesh in your funnel when you pour the oil back in your engine. Sure why not.
Old Jul 6, 2008 | 06:36 PM
QuicksilverZ33's Avatar
QuicksilverZ33
Change it quickly and just add what you lost...should def be less than 1 qt
Old Jul 6, 2008 | 06:47 PM
350Z400rwhp
Great idea, or stick your thumb in it to buy more time, just make sure its not hot!
Old Jul 6, 2008 | 06:50 PM
Blwn_By_Twins
That's what I was thinking! lol Any body know of hand what size crush washer I would need?
Old Jul 6, 2008 | 06:53 PM
citymunky's Avatar
citymunky
Go to the dealer, than are less than $1.
Old Jul 6, 2008 | 06:54 PM
SnyperZ's Avatar
SnyperZ
well it will be a good way to flush your motor
Old Jul 6, 2008 | 06:56 PM
QuicksilverZ33
+ 1
Or if you can wait a couple of days...I'll send you one tom morning...lol
I got about 15 of the factory ones...
Old Jul 6, 2008 | 07:00 PM
Blwn_By_Twins
No the bolt that's in my Greddy oil pan ig bigger, like a 22mm.
Old Jul 6, 2008 | 07:03 PM
QuicksilverZ33
oh ok...thought it was stock pan...
Old Jul 8, 2008 | 10:06 AM
gothchick's Avatar
gothchick
Greddy pan? Aluminum... You might have the beginnings of a stripped plug. May need a helicoil...
Old Jul 8, 2008 | 06:48 PM
j.arnaldo's Avatar
j.arnaldo
Is it synth' or dino'? If it's dino', change it; if it's synth', you might wanna re-
use it. Depends on your pocket's condition.
Old Jul 8, 2008 | 07:17 PM
Blwn_By_Twins
I just plugged it w/ the thumb while replacing the washer. That fixed it. Thanks everyone.
Old Jul 8, 2008 | 08:21 PM
350 Rookie's Avatar
350 Rookie
pppffft. how come nobody thought of that at first. haha
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Tochigi_236
Sep 27, 2015 03:40 PM
