Exhaust manifold studs for turbo????
are people using the stock manifold studs for turbo manifolds??? i only ask b/c i need to know if there is some sort of issue with using the studs made of the stock material.
Originally Posted by QuadCam
greddy supplies their own studs to replace the stock studs on the Greddy TT kit.
here is the reason i ask, i did not at first b/c i did not want there to be confusion.
my greddy kit was used, it did not come with hardware. i bought a new set of nissan studs and had them machined to the length specified by greddy so they would fit. i have been told that the greddy studs are the same grade as stock, just shorter.
anyways, my kit has been installed, car has been driven for about 1400 miles without abuse, then i towed the car to the dyno, the did their pre-tune check and found 7 missing manifold studs. i wanted to confirm that the OEM material is ok and that they didnt stretch or whatever, and if this is the fault of the guy who installed the kit.
Originally Posted by thawk408
Yes the stock studs are plenty strong for anything you want to bolt on.
ok, so it looks as if i need to have a little chat with my installer then.
maybe this answer will be more useful to you since you didn't like my first one.
the stock studs should be torqued to 11 ft-lb into the heads, according to the service manual.
Originally Posted by russ713
What he said. They just backed themselves out is what it sounds like.
it is hard to imagine that they backed out.
hopefully, you mechanic tightened downthe nuts on the studs. with the nut providing enough pressure, the studs would have a hard time unseating themselves...............
but stranger things have happened!
hopefully, you mechanic tightened downthe nuts on the studs. with the nut providing enough pressure, the studs would have a hard time unseating themselves...............but stranger things have happened!
is it possible that SEVEN of them broke in this amount of time?? i havent seen the car with my own eyes since this was discovered, the tuning shop is 2 hours from my house, they found the missing studs while working under the car.
i am really at a loss on what to do. it will cost me 100 bux in gas to tow it home, and no guarantee my mechanic will make it right, and if he does say he will take care of it, then we figure out the studs are broken i STILL have to pay labor.
yea, i think im Fed either way, i just need to set the damn car on fire.
Using stock studs shouldn't be a problem, and I really doubt they are broken. Sounds like they just needed a little more attention during install.
Don't forget to drop the kit off with me first.
I think your worring to much,unless your in a money crunch.exhaust studs aren't that big of a deal.Use some loctite TQ down and you should be good.What happened was one probable got lose and the others just followed suit with vibration and heat.
I don't remember the GReddy manifolds that well, but if i remember right the manifold has more holes in it than you use. The heads have 4 bolt holes around each port, but only use two of them. Are you sure your Dyno place knows that? I think they are probably seeing the empty holes and freaking out over nothing. Check the GReddy website for the install instructions to be sure though.
Check it out. Out of the 12 provided holes in the manifold, you only use 6 studs. If they told you 7 were missing, you are probably only really missing 1 stud.
Just a thought. Truly if you were missing 7, the manifold would be hanging on by a thread and the car would sound like crap...I mean there is no way you could miss the sound of seven missing exhaust manifold studs. I am guessing the shop is mistaken.
Hopefully you get some good news back.
Good luck.
