Plenum spacer with turbo...
Old Jul 29, 2008 | 08:27 PM
specialized5223's Avatar
specialized5223
Default Plenum spacer with turbo...
I've been told that upgading my plenum spacer on an FI engine will do nothing...
What's your word on this...
Thanks
Old Jul 29, 2008 | 08:31 PM
350 Rookie's Avatar
350 Rookie
I'm wondering the same thing. Im sure this has already been discussed thought so expect someone to say "SEARCH"
Old Jul 29, 2008 | 09:53 PM
350Z400rwhp's Avatar
350Z400rwhp
If it helps N/A why wouldn't it help when there is even more air being pushed through? Do it.
Old Jul 29, 2008 | 10:00 PM
z350boy's Avatar
z350boy
I had a plenum spacer added when I had the TT's done. I find it gives me a stronger mid range from about 3k - 5.5k. rpm
BTW: I have a Motordyne plenum on my '05.
Old Jul 29, 2008 | 10:16 PM
350ZTheStandard's Avatar
350ZTheStandard
^ Kewl I was wondering if it did anything on FI cars.
Old Jul 29, 2008 | 10:20 PM
cheatthe1's Avatar
cheatthe1
not sure how true that is, the airflow is simpler with the spacer in theory, but my understanding with dyno results from a local dealer is that a spacer has almost no effect on FI. I could be mistaken, but since the air is pressurized, at a given pressure it wouldnt make a noticeable difference.
My thought would be if you have 1 cu ft. air trying to get into the cylinders at 8psi, what is another .01cu ft.....
if anything i would think it would only allow faster airflow at high rpms when the blower is having more difficulty keeping up with the engine sucking air
Old Jul 29, 2008 | 10:25 PM
Cannysage's Avatar
Cannysage
spacer is NA mentality. go with an after market plenum instead.
Old Jul 29, 2008 | 10:27 PM
350Z400rwhp
This is why adding a spacer lowers boost but makes the engine more efficient and thus more power. Weather its 5 horsepower or 20, I still think a spacer is worth the money.
Old Jul 30, 2008 | 06:12 AM
SlideFox's Avatar
SlideFox
I think the saying that comes to mind is "Every little bit helps". It deffinetly won't hurt you that's for sure!
Old Jul 30, 2008 | 06:26 AM
gothchick's Avatar
gothchick
+1 couldn't have said it better... This is why cams, head work, etc all benefit FI and NA alike.
Old Jul 30, 2008 | 09:55 AM
350 Rookie's Avatar
350 Rookie
Alright so we got a bunch of opinions so far. Any shops care to pitch in and give us they test results?
Old Aug 4, 2008 | 11:45 AM
Old School's Avatar
Old School
Shift_Boost
took my plenum spacer out after it cracked...aam sucks.
hope we can retro fit a GTR plenum on the Z....I'd go with that before I'd go with anything else.
Old Aug 4, 2008 | 11:50 AM
DanielW's Avatar
DanielW
it will deffinitely help. regardless of the pressure more volume allows for more flow thats why you get such a big difference in powa from upgrading just .5" on the exhaust piping. I have a spacer for sale btW pm me if you want it.
Old Aug 4, 2008 | 02:04 PM
Hoooper's Avatar
Hoooper
dual TB's would be a good first step
for the people saying just get a new plenum, why not do both? spacer + plenum would certainly be better than just 1 of them. like said before, every bit helps, and typically when boosted every little bit helps a bunch
Old Aug 4, 2008 | 02:08 PM
turismo's Avatar
turismo
If we can find one available
Old Aug 4, 2008 | 02:12 PM
Boozt's Avatar
Boozt
I installed the APS tall boy with my STS and it made a big improvement. Car rips to redline without any flat spots it had before. I think a spacer would do the same more or less.
Old Aug 4, 2008 | 03:54 PM
specialized5223
Great info. Thanks for the input everyone!
Old Aug 4, 2008 | 05:17 PM
pmohr's Avatar
pmohr
The spacer itself cracked, or the plenum?
GT-R intake manifold on a VQ...not likely. But we shall see, I guess.
Old Aug 6, 2008 | 09:55 AM
black350's Avatar
black350
isnt the gtr's engine a VQ?
Old Aug 6, 2008 | 11:31 AM
pmohr's Avatar
pmohr
No, VR.
