After installing supercharger car does not start
Old Aug 11, 2008 | 10:16 AM
goldndwgz's Avatar
goldndwgz
if anyone has installed theyre kit do they know which wires they tapped into which color or pin numbers for the crank and cam sensors?? everytime i call stillen seems like i get a different answer
Old Aug 11, 2008 | 11:27 AM
4SHIZZIL's Avatar
4SHIZZIL
PM SuperCharged G.... I second the crank sensor...fuel is not "really" affected on the Stillen Install... Check Altenator also. Battery maybe turning things for now.
Old Aug 11, 2008 | 11:37 AM
Hoooper's Avatar
Hoooper
if the CPS isnt reading correctly/there is a problem with the reluctor ring, you dont get a spark. as soon as the ECU reads a problem from the CPS, such as extra blips, short/long blips, etc. then it stops sending spark signals. it is also possible to have that problem and not get a code for it.
Old Aug 11, 2008 | 03:43 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Dont pm me as it has been so long since i installed the sc i cant remember.And now that i installed the twins i def cant remember........plus i no longer have the instructions.
Old Aug 11, 2008 | 04:11 PM
doug's Avatar
doug
I chuckled when i read don't pm me... lol
Old Aug 12, 2008 | 01:12 AM
Blk03G35's Avatar
Blk03G35
Vacuum leak? Nice to see someone actually go with the stillen.
Old Aug 12, 2008 | 04:25 AM
reptile718's Avatar
reptile718
OP indicated to me that he has not installed the walbro fuel pump needed for this kit to function properly which could be one of the solutions to his problem.
Also he stated that he has a non rev up model but his kit has a gold pulley which is for rev ups only. The SS box comes pre tuned for this type of engine so this could also explain the problem. Only real solution here is to purchase a stage 4 for non rev up which would replace the rev up pulley and ss box????
Old Aug 12, 2008 | 03:40 PM
superchargedg
Damn Noobs
Now that comment made me laugh.
Old Aug 26, 2008 | 01:20 PM
ADMAN's Avatar
ADMAN
(1) Did you use the fuse clamp Stillen gave you? And, did you then push the fuse box cover back on? Try giggling the connection and trying it again without the fuse cover on. Sounds like your fuel pump relay. Cranks but won't run...
(2) Is your intercooler pump cycling fluid too???
(3) Pull your intake by the throttle body and spray carb cleaner into the intake and see if it runs. If so, then you have a problem with fuel delivery.
My 2 cents...
Old Aug 27, 2008 | 03:36 AM
SweetDreamZ's Avatar
SweetDreamZ
Originally Posted by ADMAN
(1) ...Try giggling... and trying it again...
i'm not sure what laughing at it will do... or perhaps you meant to jiggle it...
Old Aug 27, 2008 | 04:20 AM
reptile718's Avatar
reptile718
My 2 cents...
aarrgghh
May 1, 2022 11:04 AM
Calinismo350z
Sep 14, 2015 04:04 PM
