DDS Level 5 axles: Warning
Old Nov 8, 2008 | 09:33 PM
punish_her's Avatar
punish_her
Originally Posted by IntenseSales
We have Pros on the G35 and they include new CV's instead of using the stock ones! I believe they are not quite available to the public but can be scored upon request.
On the LV 5's I got it had come with the new CV's from DSS. The only thing that had to be done is pull the cage and bearings off the only shaft. The CV's were beefy as hell. You could easily kill a mule with it.
The first picture you can see the only part that needs tinkering with (with the exception of the BIG sticker warning). The center portion of the shaft that the cage and bearings go arround. The second picture is the CV.
So when you had a spacer made it went on the shaft side between the back of the hum and the face of the CV?
I've had no issues with tire wear, clicking, or any other problems from these (knock on wood).
Attached Thumbnails DDS Level 5 axles: Warning-dscn2965.jpg   DDS Level 5 axles: Warning-dscn2966.jpg
Old Nov 9, 2008 | 07:02 AM
meatbag's Avatar
meatbag
Jack the rear end of your car up and see if you wheels have any side to side play in them.
Old Nov 10, 2008 | 06:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by kevinapex
I have level 5s also. less than 200 miles all the cap bolts that hold the shaft to the cv walked out!
The tq specs. read 38 ft.lb... thats what I did 38 no thread lock either.
I got all new cap bolts from a fastener shop, and some red rubber thread lock material called Vibra-Tight, tq them to 70ftlbs all is well.
The shop has sense changed the tq. spec!!!
Tore up the inside of the hub from the cap heads extending out, sucked!
Kevin
Those caps waked out on my as well. It essentially bored the inside hub out as they backed out, causing me to almost sheer off 2 bolts holding the caliper bracket!
Had them TQ's with an air gun and used threadlock dont have any issues.
I have not experience issues like the OP and some of you though, BUT I will check next time the car is in the air. Thanks for the info!!!!!!!!
Old Nov 10, 2008 | 06:49 AM
ttg35fort's Avatar
ttg35fort
Professional
I have the DDS Level 2 axles. I have had no problems yet, and I pushed it relatively hard at times at Sebring with 12 psi of boost. Has anybody had any problems with the Level 2s?
Also, has anyone pushed them much past 500 hp with drag slicks and a 4k rpm launch? I'm setup for the road course, but I wouldn't mind seeing what my car will do in the 1/4 mile once my current round of mods are finished, which should be December assuming I get the Cosworth in by then.
Old Nov 10, 2008 | 08:55 AM
Cass007's Avatar
Cass007
You know that your Cosworth is NEVER coming right?
Old Nov 10, 2008 | 01:58 PM
ttg35fort's Avatar
ttg35fort
Professional
According to Marty at Injected Performance, it is shipping today 2nd day air. Should have it on Wednesday.
Old Nov 12, 2008 | 08:06 AM
rrmedicx's Avatar
rrmedicx
Can anyone take Punisher's pics and point out the precise point of failure. I don't think I am understanding where the failure is occurring and where the spacers need to go? Also which bolts are backing out? Thanks.
Old Nov 12, 2008 | 08:51 AM
RollinTurtle's Avatar
RollinTurtle
yeah i think i helped meatbag pull his bearings after he had the same problem with his . Not sure if it ever got resolved. Iam assuming so since its good enough to get Freebirds on a Saturday afternoon
Old Nov 12, 2008 | 11:50 AM
meatbag's Avatar
meatbag
Yeah that time we did it was the 3rd set of bearings.
The bearing failure problem is an engineering problem from the Driveshaft Shop. The face that butts up to the backside of the bearing is considerable smaller then the stock one and puts way more torsional loads on the bearings. DSS told me over the phone that they were going to machine the faces down on my axles and put a flange on that was bigger to spread the load out more over the back face of the bearing. But they didnt do any of that and I am still having the same problems. I paid about $100 both ways to have them overnighted to them and the only thing it looks like they did was put a coat of paint on them and ship them back to me.
Old Oct 4, 2009 | 03:25 PM
str8dum1's Avatar
str8dum1
Bumping an old thread,
So whats the current deal with these Level 5 axles. I just broke my stockers at the drag strip and need to upgrade anyhow to support the new power coming.
Intense mentioned "pro" revisions with installed inner CVs. Any new info on that?
Any info more experience in general?
Thanks!
Old Oct 4, 2009 | 04:58 PM
05Z33's Avatar
05Z33
Does anyone know what our stock axels can handle?
Old Oct 4, 2009 | 05:03 PM
str8dum1's Avatar
str8dum1
well less than 450 hp if you dont preload the drivetrain obviously
and guys have popped them with much less HP based on other threads. much closer to sub 400
Old Oct 4, 2009 | 08:08 PM
rcdash's Avatar
rcdash
^^ Well that's not good. Great, more parts to buy. +1 on whether this is the final end-all be-all for axle solutions...
Old Oct 22, 2009 | 01:15 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I broke a stock axle 4 years ago with 255rwhp and a mess up while I was staging on slicks.
Old Oct 22, 2009 | 08:24 PM
JET MECH's Avatar
JET MECH
wheel hop will finish the stockers off in a hurry!!! i speak from experiance.....
Old Oct 22, 2009 | 09:34 PM
str8dum1's Avatar
str8dum1
none of us had wheel hop that broke recently..... we snapped right off the line.
Old Oct 23, 2009 | 02:09 PM
Resmarted's Avatar
Resmarted
Yeah +1 what's the dill here yo?
did dds refund or help you?
It wouldn't be too bad if they managed to replace a few parts or something... (but then again I would still be po'd)
Old Oct 23, 2009 | 07:49 PM
  #38
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Ok, it's wrong in the title of the thread and wrong in like 20 posts in here.
It's DSS people, not DDS.
DriveShaft Shop
416blueZ
Jun 11, 2024 10:56 AM
sales@czp
Sep 23, 2019 03:30 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
416blueZ
Sep 24, 2015 02:11 PM
