Going Forced Induction PETT build
Old Nov 19, 2008 | 05:18 AM
  #41
jtgli's Avatar
jtgli
Your fine with the way that he tuned it. And the fact that it was Dave your fine. If anyone else Id even tell you to change the springs and then slap you for not taking it to Dave in the first place. So relax with what anyone says on here. If Dave says your fine, your fine.
Old Nov 21, 2008 | 10:06 AM
  #42
Blck350z's Avatar
Blck350z
Hey guys wondering if a couple drips of oil is OK on my garage floor until next spring.... I think i know where its coming from but i don't really want to get under my car on the cold garage floor..... if I keep it filled up until then I should be OK correct???? Thanks for your help
Old Nov 21, 2008 | 06:11 PM
  #43
Car vs. Driver's Avatar
Car vs. Driver
Are you presently driving the car or is it just sitting for the winter? If you're driving it, fix it before it becomes an even bigger problem.
Old Nov 21, 2008 | 10:55 PM
  #44
Kal_El's Avatar
Kal_El
Congrats man! Dyno looks great, we are probably around the same whp range. I'm glad it all worked out and I know you must love the fast TQ curve! So you are at 12 psi right now?
Old Nov 23, 2008 | 01:42 PM
  #45
Blck350z's Avatar
Blck350z
Yeah 12 psi.... the HKS EVC said it spiked at 13.2 psi the other night.... i think b/c its so cold out. Anyways its a blast to drive!!!!!
Old Nov 23, 2008 | 07:39 PM
  #46
Kal_El's Avatar
Kal_El
man! I'm right at 8.7psi, I would love to turn it up to 13psi but I have a feeling my rods wouldn't hold. I wish you were here, would love to ride in it. Very glad you went through with it and that you are happy!
Old Nov 23, 2008 | 11:20 PM
  #47
wannabuy350z's Avatar
wannabuy350z
I am also currently running 11-12 PSI on my jwt 530 for the last couple of months. but arent the PE kit turbos much larger?
Old Nov 24, 2008 | 01:21 AM
  #48
Dynasty.Zero's Avatar
Dynasty.Zero
You know the solution to that problem.
Old Nov 24, 2008 | 01:22 AM
  #49
Dynasty.Zero
Comparable I think . . . I know those IHI turbos are very small.
Old Nov 24, 2008 | 06:54 PM
  #50
Blck350z's Avatar
Blck350z
Kal, your making comparable hp and tq at 8.7 psi???? so is there really that much fuel added and timing retarded to have me making the same power as you??? i'd like to see what my setup could do on a built block etc...!!!!!
Old Nov 24, 2008 | 07:49 PM
  #51
Kal_El's Avatar
Kal_El
haha...I know and I wish....
Pretty much, from what I understand, the PE1420 turbos are probably the smallest available for the Z33.
Man, I'm not too sure on the details of how your tune went. I know I have PE 510cc injectors and what not. Man on a built block, just look at Cheston's Z. I believe when they dynoed for the Sport Compact Car Challenge he made 525WHP and 492lbs TQ!! We are just pretty fortunate to have some great guys at Technosquare, I don't even have an aftermarket EMS. Maybe a short block this summer....
Old Nov 24, 2008 | 08:19 PM
  #52
Dynasty.Zero
DO IIIITTTTTT!!!
Old Nov 24, 2008 | 09:27 PM
  #53
350z-900whp's Avatar
350z-900whp
i did on mine 477whp/497wtq on 14psi and 503whp/534tq on 16 psi stock heads and cams
you could be in middle of 500's whp and high 500 tq given that u have built long block with cams
Old Nov 24, 2008 | 11:27 PM
  #54
Dynasty.Zero
Altitude makes a difference too.
350Z_Al
Oct 29, 2020 07:44 PM
