Going Forced Induction PETT build
Old Aug 24, 2008 | 09:13 AM
Blck350z's Avatar
Blck350z
Talking Going Forced Induction PETT build
Hey guys, I thought i'd post up pics and updates as I do my PE TT kit install.... I wasn't expecting to do this so soon, but after riding around in the FI Z's I couldn't help myself ( Its very addicting ). As of right now I have everything ( I think ) except my utec and the time to install it. So while I get those last two things check out my build list and see if I'm missing something. Thanks and check back for updates!!!
Before...:
where she sleeps at night.....
the inside:
the outside:
Hopefully this will have an intercooler in it soon!!
and the kit.....
The build list:
-PE TT kit w/ SS headers ( I know I know, but my welder is re-inforcing the welds and trying to rig up a bracket.... we'll see how that goes)
-RC550 injectors w/ pnp clips
-AAM Fuel return basic
-Walbro 255lph pump
-AAM 3" true dual exhaust
-APS 3.5" Test Pipes
-AAM plenum spacer
-HKS SSQV BOV
-HKS EVC 6
-HKS Turbo Timer Type 0
-Turbo XS Utec ( will be here soon )
-NGK Iriduim One step colder plugs
-AEM UEGO A/F gauge
-Autometer boost gauge.
That about wraps it up..... if you guys can thinkg of anything else please let me know
Getting a lot of help from JTGLI and mad props go out to him for all of his help already
Old Aug 24, 2008 | 11:40 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Nice and good luck installing it........whos going to tune it.
Old Aug 24, 2008 | 12:13 PM
weslutes's Avatar
weslutes
Sweet.
The install isn't too bad. Just take your time.
You can water cool those turbos.
While you're at it, add a KOYO
Old Aug 24, 2008 | 02:45 PM
Blck350z's Avatar
Blck350z
More than likely Dave at Function will tune it.
"weslutes" whats the advantage to water cooling it???? j/w i may be interested.
Thanks guys
Old Aug 24, 2008 | 02:53 PM
Chebosto's Avatar
Chebosto
get a better radiator than KOYO. its worth the extra $ for the PE one.. which is basically a ARC radiator rebadged, and 400 bucks cheaper
you dont need the plenum spacer if ur going turbo, but hey, its your decision.
if you're gonna be doing some track work. i highly suggest an oil cooler.
but overall. welcome to the PEtt club
... and start saving up for the cast manifolds while you're at it.. just a matter of time..
Old Aug 25, 2008 | 02:29 PM
superchargedg
Damn Noobs
Thanks guys
Good choice.
Old Aug 25, 2008 | 02:32 PM
zulator03's Avatar
zulator03
did i see ice wax in a picture
Old Aug 25, 2008 | 02:39 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Beautiful front bumper man, cars really coming along! I love it!!
Suggestions:
radiator, oil cooler, nismo t-stat.
Old Aug 25, 2008 | 05:57 PM
Kal_El's Avatar
Kal_El
Lookin great so far John. Like the looks of the car and thanks again for the tips on the diffuser. Good luck and let me know when it's done!!
Old Aug 25, 2008 | 05:58 PM
Nexx's Avatar
Nexx
Suggestions:
amen to that!
Old Aug 26, 2008 | 09:57 AM
Blck350z's Avatar
Blck350z
Thanks for the tips guys....and the compliments, i've changed my mind about 2000435221343 times about how I wanted to do things...
Old Aug 26, 2008 | 10:14 AM
wannabuy350z's Avatar
wannabuy350z
with the new power you want to have a good suspension. Drop it!
Old Aug 26, 2008 | 03:37 PM
Chebosto's Avatar
Chebosto
oh wait. i just saw the picts.
the intercooler the way it is.. i think you have a G35 pett kit. not the one for the Z... the intercooler inlet is on the bottom, which the outlet is on top. to gothru the radiator support frame.
like this:
Old Aug 26, 2008 | 03:43 PM
jtgli's Avatar
jtgli
It looks like it was a Z in the GTM build thread...maybe they changed it?
Old Aug 26, 2008 | 03:55 PM
thawk408's Avatar
thawk408
To be honest I would rather have a reinforced SS manifold then a cast, with all the greddy cast manifolds cracking also.
Old Aug 26, 2008 | 04:01 PM
Chebosto's Avatar
Chebosto
i reinforced my SS manifold with extra welds and did a heat treatment, and both sides cracked.. sigh.
as far as the cast cracking? wow. really? who's?
Old Aug 26, 2008 | 04:34 PM
Floridaboy1605's Avatar
Floridaboy1605
Dont worry we will make it all work!!!
Old Aug 26, 2008 | 08:05 PM
thawk408's Avatar
thawk408
Mine cracked on the passenger side manifold. Several others have also.
Old Aug 26, 2008 | 08:16 PM
BlinkerFluid's Avatar
BlinkerFluid
Ha, had to do a double take on the location when I saw the Bob 94.9 banner in the background of one of the pics.
We'll have to get all the boosted G35/350Z together when I get home, seems there are quite a few in the area now.
Old Aug 26, 2008 | 08:46 PM
weslutes's Avatar
weslutes
Yep, I've seen the PE casted manifolds crack too. So nothings for sure.
I could only guess that the weight of the exhaust did the damage at high temps. The twisting of the motor during acceleration probably added to the stress on the manifolds.
I have the AAM TP also & they don't have mounting brackets. You may want to look into having something installed for support. Maybe an engine torque damper or solid motor mounts. Maybe even some flex pipe after the TP's.
Water cooling lowers temps & helps prolong the life of the turbo.
Oil cooler is a good idea too. I got the Stillen, pricey but easy install. Even if you choose a different location.
