Smoke coming from exhaust...
Old Aug 25, 2008 | 12:48 PM
04LIQUIDSILVER's Avatar
04LIQUIDSILVER
Default Smoke coming from exhaust...
Please help... I got a turbonetics kit on my car for about 4500 milles and on the last 2 days lots of smoke come from exhaust when I let go the gass after full trotle.... this is freaking me out is this a signal of my turbo seals going bad.......... if so where to get a replacement from turbonetics... I know some one on the forum works @ turbonetics please chime in...
thanks
Old Aug 25, 2008 | 12:50 PM
wannabuy350z's Avatar
wannabuy350z
oil passing you seals. talk to reggie at turbonetics and have them replace your turbo under the warranty with a water cooled turbo
Old Aug 25, 2008 | 12:52 PM
04LIQUIDSILVER
I have the second generation (water cooled) and Is not under warranty I got it use from some one here on the forum....
Is Reggie here on the forum?
Old Aug 25, 2008 | 01:02 PM
wannabuy350z
Dont know. in regards to your turbo, its kinda common on decel you get smoke. as long as your not getting smoke from idle or partial throttle or WOT, I think your fine.
is it a lot of smoke?
Old Aug 25, 2008 | 01:13 PM
04LIQUIDSILVER
Yes it is.... It's smoking so bad that I got people on the road telling me that my car is smoking and you can smell burn oil.... and it's after WOT I just found a few threads about this and a few videos from MYAPLAYA and is the same thing with my car... I just send a PM to Reggie (BLK180SX)
thanks for helping
Old Aug 25, 2008 | 01:26 PM
twin001's Avatar
twin001
Check your oil feed and return lines. I bought a turbo kit for a different car of mine and the instructions said to route the oil return line in a manner that positioned it right next to the turbine housing. Over time the heat from the turbine housing melted the SS return line causing oil to spew everywhere.
Also, check the gaskets to your feed/return lines. They may need to be replaced with new ones. I hope it's nothing worse than what I've described. If your cartridge is bad then you may need to send it off to be rebuilt. Call Majestic Turbo to see what they can do for you.
Good Luck!
Old Aug 25, 2008 | 02:31 PM
04LIQUIDSILVER
Good Luck!
did any one know how much a shop will charge to remove old turbo and install new one... I have to start saving money for this now
Old Aug 25, 2008 | 02:34 PM
carfi179's Avatar
carfi179
400-500, just do it yourself its not hard just time consuming ( tightening the bolts below the turbo)
Old Aug 25, 2008 | 02:42 PM
04LIQUIDSILVER
Ill try do it my self... now just waiting on turbonetics to see how much they want for a new turbo
Old Aug 26, 2008 | 11:21 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
For a price on a new turbo and install contact Vinny Ten. Vinny is in west babylon ( Long Island ) 631-414-7590.
Few things to check for also:
Blowby ( internal engine problem )
Obstructed air inlet to turbo
Obstructed engine crankcase vent
Hole in oil pan must be same size as oil drain
Excessive oil pressure
Oil Drain lines kinked or clogged
Drain must be above oil level
Old Aug 26, 2008 | 02:04 PM
rcdash's Avatar
rcdash
Blocked PCV will cause the same symptoms. It's a $10 part and takes 10 minutes to check out if you have the large socket to remove the PCV valve.
Old Aug 26, 2008 | 02:36 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Very common and easy to miss also...........
Old Aug 26, 2008 | 02:48 PM
04LIQUIDSILVER
thanks guys I'm waiting for Reggie from turbonetics.... wishme the best....
also do es any one has the extension to Reggie please?
Old Aug 26, 2008 | 05:10 PM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Damn ***** sorry to hear.. if u need help on doing the work.. lmk Ill come by and help
Old Aug 26, 2008 | 05:22 PM
04LIQUIDSILVER
Thanks bro I might need a hand I'll let you know
Old Aug 27, 2008 | 10:26 AM
350 Rookie's Avatar
350 Rookie
Where in NY are you. Ill come and do it for like 250 bucks.
Old Aug 27, 2008 | 10:37 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Now you're mechanic..............I would not take that offer and I would not trust him at all. Zthirty offered help but to have Eddie Ghani help you is bad news search his name for all the threads he posted where he needed help himself. Did you complete your UTI weekend course or something?.......
Old Aug 27, 2008 | 01:00 PM
350 Rookie's Avatar
350 Rookie
Well you guys obviously cant do shit right so move aside. And if these stupid kits stop having problems, i wouldnt be having any threads.
Old Aug 27, 2008 | 01:09 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
It's not my fault you got PWN3D for lying and getting caught and you have ZERO mechanical skills and or brains.
You PHAYLE.................
Old Aug 27, 2008 | 01:12 PM
Vas@Extended
Come on guys stop going OT... Lets help my friend here. *****- Did u speak to Reggie from turbonetics yet?
