twun turbo on the way
Old Sep 9, 2008 | 03:12 PM
zulator03's Avatar
zulator03
Exclamation twun turbo on the way
i gettin my car back from cali then got a sh*t load of parts check them out tell me what you think
eagle rods
greddy tic dual exhaust
-wiseco Pistons
-Carbonetics triple disc clutch or twin clutch
BC stg2 cams
CJM Fuel Return System
- uhaltech ems
- DeatschWerks Fuel Injectors 800cc
-Boost controller - greddy profect b 2 turbo
-defi Boost gauge
Aem boost
defi Oil pressure guage
going for around 500 or 600 hp
Old Sep 9, 2008 | 03:34 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
ARP studs? L19's? Head Gasket?
Otherwise looking good
Old Sep 9, 2008 | 03:37 PM
zulator03's Avatar
zulator03
thanks
Old Sep 9, 2008 | 04:26 PM
wannabuy350z's Avatar
wannabuy350z
eagle rods
-wiseco Pistons
BC stg2 cams
- uhaltech ems
-defi Boost gauge
Aem boost
why two boost gauges
Old Sep 9, 2008 | 04:31 PM
eltness350's Avatar
eltness350
The Untouchable
+1 on the arp hardware and head gasket, do some port/polish work and upgrade the springs minimum for those cams if u got the cash, get aam 3inch downpipes/w dumps...as for pistons i went with arias extreme duty....nice list so far
Old Sep 9, 2008 | 06:42 PM
zulator03's Avatar
zulator03
srry added 2 idk y
Old Sep 9, 2008 | 06:44 PM
ttg35fort's Avatar
ttg35fort
Professional
Nice list!!! I researched the shiat out of the various rods and pistons, and also went with Eagle Rods and Wiseco Pistons.
I actually asked by engine short block builder (Kyle at import parts pro) his opinion about going with the Carillo Rod/Arias Piston combo, and he said that my money would be better spent on applying ceramic coating to the top of the pistons and moly coating the side skirts. So that's what I did.
If you are going turbo, be sure to get the "Turbo Ti-C" exhaust.
zulator03's Avatar
zulator03
Originally Posted by eltness350
+1 on the arp hardware and head gasket, , get aam 3inch downpipes/w dumps...as for pistons i went with arias extreme duty....nice list so far
yea i was going qith aam 3inch and maby chane pistons idk yet but what do u mean by do some port/polish work and upgrade the springs minimum for those cams if u got the cash tad bit retarded lol
Old Sep 9, 2008 | 06:51 PM
zulator03's Avatar
zulator03
any 1 else wanna chime in that would be nice
Old Sep 9, 2008 | 07:18 PM
chris'smax's Avatar
chris'smax
typing in correct english would be a nice start
Old Sep 9, 2008 | 10:13 PM
ttg35fort's Avatar
ttg35fort
Professional
+1 on the valve springs.
Also, go with a Walbro fuel pump (or two if you want to spend the cash on a twin setup).
Definitely go with a Motordyne 5/16" plenum spacer OR a Cosworth Plenum. But your talking Approximately $200 for the spacer vs Approximately $1200 for the Cosworth. So that depends on your budget.
In my opinion, save the money on the Arias pistons and put it toward ceramic/moly coating on the Wiseco pistons. It is my understanding that the ceramic/moly coated Wiseco pistons will give better performance than uncoated Arias pistions in your hp range, and save some money at the same time. If money is no object, then you can apply the ceramic/moly coating to the Arias pistons, but I have not seen any credible evidence that they will perform noticably better than the Wiseco pistions at hp levels you will be running, although they are very slightly ligher (maybe 20 mg or so).
There are some who actually contend Wiseco pistons hold tighter tolerances and are generally made better, and outside the VQ35 community Wiseco pistons have a very good reputation:
http://hondaswap.com/forced-inductio...vs-ross-40393/
http://hondaswap.com/engine-building...eco-etc-43423/
It also has been suggested that Wiseco actually supplies rings to Arias:
http://www.isuzuperformance.com/bills/engpistons.html
Nonetheless, in the VQ community Arias seems to have a very good reputation, and are used by some very reputable builders. In the end, you should probably go with what your engine builder recommends. Like I said, although my engine builder sells Arias pistons, I asked him if this were his motor and his money, what would he do? That's when he recommended ceramic/moly coated Wiseco pistons for my application. My tuner concurred with his opinion.
Old Sep 9, 2008 | 10:22 PM
ttg35fort's Avatar
ttg35fort
Professional
Here is a link to my build, although there are some changes from the original listing because I upped my hp goal:
https://my350z.com/forum/forced-indu...under-way.html
I changed out the APS 2.5" exhaust/test pipes for the Greddy Evo TT with custom test pipes and a SGP W/G relocation kit, feeding the dumps back into the exhaust. Tomorrow I'm ordering larger fuel injectors and I am going with a twin in-tank Walbro fuel pump setup.
bcoffee20
Nov 19, 2015 06:39 PM
